• It's our birthday and YOU get the gifts! Eight giveaways including six watches that you can enter for free! RWI Birthday Free Gifts Link
Vsf / xf sea dweller now comes with vs3235 !
Slugger
Absent Minded Professor
2,127
1,739
If anybody wants/needs a ceramic insert for their SD-43, I‘ve been looking around and finally found some CF inserts offered by Sillan (guangzhou) Watch Co., Ltd. Their minimum order is two. If anybody wants to piggy back on my order, let me know. Here is a link to the description.
ombre
So Young...So Naive
924
951
Usually if you message them they will sell you just one.
Reactions: m5smg2
guybythelake
351
164
The description for this insert is all over the place. It says it will fit 40mm, Deep Sea Sea Dweller (44 mm) or 126660 (43 mm - this thread). They are different size bezels - inserts and the quality (from pics) is not all that compared to VSF.
Slugger
2,127
1,739
The dimensions of the insert are 40.2 mm x 31.6mm. If that’s not what you’re looking for, these aren’t for you.
Slugger
2,127
1,739
Oh, and BTW they are not VSF inserts. The description says they are CF.
Except for movements, which aren’t actually made by VSF, I haven’t had much luck sourcing VSF parts. If that’s what you want and you can get it, great!
guybythelake
351
164
Ok. That make sense, the size of the insert is about 40 mm... I also just found out both my DDSD and SD 43 use the same size bezel! I thought they would be different, one being a 44mm case vs 43mm case. So yeah, they should fit. BTW I know these inserts are advertised as Clean, I don't know if they really are or not since Clean does not make a DSSD or SD43 but the quality is not bad after I took a second look. This is a decent option; Thanks for sharing and extra explanation.
ernien
810
217
Canada
Have they finally fixed the cyclops magnification!? Here are some qc’s (not mine) from this week. Looks good!
nennca
Anyone knows if the VS insert fits the ARF bezel ?
Reto
133
49
Did VSF fix the magnification issues? It looks like it
