VSF Submariner VS3235 Gen Parts Installation Project
dogwood
2,532
5,794
Canada
Are these 4 parts the only ones you ended up swapping in the end? And can I please ask how much did it cost in the end? Thanks
It’s not really necessary to do the winding intermediate gear anymore since the Dandong version is now perfectly adequate. So the three parts that you’d want to upgrade for a “gen like experience” would be:
  1. The balance complete
  2. The pallet fork
  3. The escape wheel
StanGENROL
Watches passion and mechanics behind it!
132
39
Essex
In my case it started gen but since my one gen 3235 had serious issues I had to strip it down and replace or mix gen with vsf parts, now my project is 98.99% gen few parts still vsf but just yesterday ordered few other parts to get on to my 3235 movement which then will eliminate even further vsf, my project costed me £3980 I recon by end with all gens parts on case with gen 126610LN hands and crystal and gaskets will be £4300 let’s say for this money you can get nice fully gen two tone DJ 36mm or omega for just under £2900, or even Tudor brand new for £3600 not going to even mention Breitling with their vast collection great watches! Got gen Colt Chronograph on steel bracelet 2017! Stunning watch
Reactions: dogwood
TonyMontana
99
23
  2. The pallet fork
  3. The escape wheel
Perfect, thanks alot
beng7
58
32
Since a bunch of you in here are modding i thought maybe someone would have a spare part i need from a VS3235. I need these two little pillar bushings, they're located under the train wheel bridge, and then under the bridge that supports the center wheel. I attached a pic of the bridge which I don't need, i need the 2 pillar bushings that sit around the two screw holes that support this bridge pictured on white. Pointed to them on the base plate with arrows, and took a pic of it on a green background as good as i could with it being so tiny. I tried pulling them from a clean movement, but the same pillar bushings are a different height on cleans 3235. I actually only need one but if you have 2 i'll take both incase there are any size differences, the bushing flew off my bench and dissapeared into the abyss. If you have em drop me a message.
harry4444
MULTI ACCOUNT
25/11/24
22
11
Thank you everyone Very Informative Thread I learned a Lot Here
dogwood
2,532
5,794
Canada
I have a couple of spares. DM me if you still need them. I’ll setup a reserved sales thread.
Reactions: beng7
Raymond
268
87
In an effort to expand my watch "smith" skills, I decided it would be a fun project to order some gen parts for my VS3235 movement and see if I could install them without hurting myself (other than my wallet), and see if the movement was any better off for the trouble. The parts I decided to swap for gen were:
  1. Crown Wheel (part no. 3235-213)
  2. Balance Bridge (part no. 3235-120)
  3. Balance Complete (part no. 3235-432)
My reasons for doing these three parts specifically were that I'd read in Logixa amazing teardown thread that the crown wheel on the VS3235 could have some issue due to the spring washer rubbing and producing metal shavings that would damage the movement long term. As for the balance complete and the balance bridge; those I decided to swap to gen because I wanted to see how well I could regulate the movement using the microstella nuts as opposed to using the regulation arm on the stock VS3235.
So, here's a pic of the gen parts.
And just to get a baseline of the movement's health, here's what it looks like on the timegrapher *before* I've installed any of the new gen parts.
If you were a normal person, you'd look at that timegrapher result, and say "if it ain't broke, don't fix it"... fortunately, in this community we are not normal. And that's how I began to disassemble a perfectly good watch to install expensive genuine parts into a watch that clearly didn't need them to function. Onwards!
After taking the movement out of the case and removing the automatic mechanism, balance, and main train bridge, I was able to access the bit of the watch that I was planning on replacing. First up was the escape wheel. The gen version is beautifully skeletonized. Here's a pic of the Gen and VS versions under my digital microscope. There's a real difference in the finish quality (and maybe a difference in geometry -- more on this in a minute).
The crown wheel is also accessible from under the main train bridge. The difference here between the gen and the VS parts is more subtle. It's basically impossible to tell the two parts from one another without the aid of magnification. But under magnification, it's possible to see that the gen part has a much nicer finish.
The install of the crown wheel was very straight forward. I simply dropped it into place and was done. It was the same story for the escape wheel. I took out the old one, and put in the new one, re-assembled the train of wheels and then re-installed the train bridge. The train bridge went into place without any trouble and I screwed everything back down. Although when I got the pallet fork re-installed it didn't seem like the VS pallet fork and the gen escape wheel were playing that nicely with eachother. I put a little wind onto the main spring to see if I could manually actuate the pallet fork, but it looks like the VS pallet fork isn't quite right for locking and unlocking the gen escape wheel. For those who've done something like this before, did you need to replace both the escape wheel AND the pallet fork with a Gen in order for it to work?
Next was the balance and balance bridge. I'd read that sometimes that balance bridge won't quite sit properly on the VS mainplate's centering pins, and that sometimes you need to broach the holes on the gen bridge. I tried without broaching, and while *slightly* tighter than the stock balance bridge, the gen bridge fit without the need for any broaching.
With the knowledge that the balance bridge would fit onto the main plate, I decided I'd try to connect my balance complete with the balance bridge. This was really hard. Is there a tool or jig that would make this easier? I was using two pairs of tweezers; one to hold the bridge, and one to grab the little anchor thingy on the end of the hairspring, then I'd try to move the hairspring anchor thingy into the slot on the balance bridge's hairspring stud. I managed to do this once, but then I needed to somehow change tools to get a screwdriver to tighten the hairspring stud screw. While I was doing so, the anchor thingy came out of the stud slot. My arms were getting a bit tired at this point so I called it a day. If anybody has any suggestions on how to make this process a bit easier I'd love to hear.
And finally, a pic comparing the gen balance bridge with the VS balance bridge + balance complete. There really is a difference in finish quality at high magnification.
Where can I pick up the vs 3235 , I see a bunch of 3235 but they are vf and different factory’s?
Thanks
Raymond
268
87
The vs3235 can be acquired from many of the TDs. Or there’s a seller on Alibaba named Sillian who sells them (MOQ = 2).
Thank you for the info . I contacted them last night about the 5 digit sub case .
Watch_Tinkerer
31
Got my most parts, had to buy donor vsf3235 fully brand new sub 126610LN and that costed me 650£ plus genuine parts crystal and lots of other genuine parts down to the hands and most moving parts as the bridges and date disk and balance wheel and all those, looking into my watch would be near impossible to actually say it’s RP as even main plate I got is the generic replacement plate same machining and manufacturing as Rolex or to standards this plate is used for repairs and service if not mistaken, correct me guys if wrong, thanks all soon will post some great photos!
The process of building is so so so much satisfying and enjoyable!
I guess this pice now worth a few thousands as 98% of movement is genuine and all rest on exterior is about 57/65% genuine!
Actually case and strap and clasp is from my previous brand new Clean Factory 126610LN
Just waiting for my date disk and gaskets!
Actually even crown and steam is all genuine
Hey there, I'm also working on my project like yours. Would you be able to point me in the direction where I can find such main plate. I'm also looking for one for my gen parts.
dbs
37
37
This part, including the bridge, and second wheel, VSF and GEN are NOT interchangeable. If you replace, the second wheel will jam.
I did the whole project at the first year VSF 3235 was released. This and date jump/date disc are not interchangeable (unless you have GEN 3235-100 main plate), and also the cap jewel on main plate side.
Reactions: dogwood
beng7
58
32
It's possible i have all gen parts installed in mine except the main plate. I did have to adjust the jewel depth on one of the train bridge jewels though. I'm just waiting for a replacement dial then i'll post pictures of mine finished. The date Jumper assembly and disk worked with no issues for me.
beng7
58
32
I am interestested to see though if i swap in the part above and the second wheel if my amplitude increases i'm at 0, 268, 0 now but perhaps i will go much higher if i use the rep parts for those two. I'll check it before i case it all back up in the next week or so when the dial comes.
beng7
58
32
When you say cap jewel are you referring to the balance jewel in the shock setting on the dial side on the main plate? If so i used all rep jewels on the main plate. Those bushings i was able to get from another member here.
Watch_Tinkerer
31
Spaceballer
95
135
33
United States
I have the bushings if needed.
dbs
37
37
I mean the whole balance jewel assy. The main reason is, the hole on VSF 3235-100 main plate is bigger than Rolex cap diameter.
dbs
37
37
You cannot. There are several sellers on ebay selling 3235-100 main plate. But they are all fake ones. 3235-100 has serial number so it is extremely hard to find.
At the time of VSF first release 3235, VSF (or, xxxx watch factory) selling 3235 as a whole movement for $8000 but I missed. When I look at back on how much I spent on ordering gen parts, it is about this amount. But, there's no medicine for remorse.
beng7
58
32
I replaced all bridges with gen, but if you mean the jewel on the plate the bottom balance wheel pivot sits in on the VSF 3235 main plate i had no issue with this, just removed the shock setting and oiled it appropriately.
