stufuse
3,659
2,457
What about dial aperture for the 3
muiramas
Aristocrat
18/1/17
6,036
7,931
Now for the crystal, I think Duckber is right here.
Anti-reflective coating.
The new Submariner and Submariner Date models feature an anti-reflective coating on the crystal preventing glare. This is the first time that a Submariner model has this on the crystal.
fatarms described this best. AR on the inside does not really reduce glare - light will bounce off outside of the crystal the same as it always did. It makes the dial more legible by reducing the reflection of the dial, hands and marker back onto itself from the inside of the crystal.
This isn't a scientific analysis by any measure, but you can see the difference clearly - the Sinn 103, Left has 2 x AR on the outside, The Sinn UX has AR on the inside, and the VSF on the end. The reflection of the lamp is bigger on the VSF simply because is was closer to the light. I only noticed that when I made the comp and I don't have time to photograph and comp it again.
Edit - a detailed comparison between the UX and the VSF is not useful. The UX has a matt dial and hands and is filled with oil.
Reactions: Jayalvin777
UnluckyXIII
124
66
Rolex Submariner Date 126610
Diameter: 40.5 mm
Lug to lug: 47.6 mm
Clasp: 18.83 mm
Lug width: 26.7 mm
Thickness: 12 mm
SEL 21mm
Last Link 16,5mm
Here is the difference to 116610
I took my time and measured it with a caliper, so maybe it varies by 0,1 - 0,2 mm ;)
VSF Submariner Date 126610
Diameter: 40,6mm
Lug to lug: 47.6 mm
Clasp: 18.97 mm
Lug width: 26.7 mm
Thickness: 12,80 mm
SEL 21mm
Last Link 16,5mm
Here we can see it is nearly to gen specification.
Only the thickness is a bit more ( I have the foil on the caseback)
Gesendet von meinem Mi MIX 2S mit Tapatalk
Great info and very helpful to see where things currently stand, aside from case thickness I think we are in a great place.
Jacobs89
36
so for new VSF 126610 will be same crystal as for 116610? Im confused, sorry if I’ve asked stupid question?!
Jacobs89
36
Jacobs89
36
Jacobs89
36
apologies guys my phone its just freaked out! apologies again for trashing treat!
Reactions: jiro
alexcast
224
172
I just blocked him I so I don’t know date my time reading his bs
Enviado desde mi iPhone utilizando Tapatalk
I meant I just blocked that bear guy I don’t like wasting my time reading bs about a rep he ain’t bought
Jacobs89
36
already ordered few days ago???? and waiting for delivery. peace and love
Reactions: YellowFin
tribal
806
697
Calm down guys, those double post where generated using Tapatalk. ;)
Mille M
1,254
2,759
Can't speak for the VSF 126610, because I don't have it with me yet.
But, my VSF Yachtmaster 42mm has a reaaly nice crystal, with nice AR.
My ARF Submariner V3 reflects the hour markers a lot more - the light hits the markets, reflect them on the underside of the crystal and then bouce to the glossy dial, creating this effect.
(Gen sub)
The Yachtmaster 42 is much better in this regard (my VSF YM 42)
I'm guessing that the 126610 will have a similar treatment to it's crystal...
