LowKeyNovice
- 27
- 8
- 0
Guys my sub tracking info says "delivered" and it isn't at my door or in the mailbox. I want to cry, lol.
Gen clasp is 18.96?
it's only a slight difference. Jenny on Youtube measure it 18,83 mm.
So to summarize the clasp width:
Batch 1 : H7Z 19,4 mm
Batch 2 : 1QL 18,96 mm
No, for this I must take the watch apart to get right dimensions.tribal Are you able to messure thickness of just the case for all 3 models? Gen new, Gen old, VSF ?
Bezel protector rubber is stiffer than gen, huge tell from across the room. I sometimes do wonder what you guys even care about...Thank you my friend amazing packaging.
Tags are 1:1 and bezel protector genlike
Mine is 12.5mm thick, are you sure your case back is fully tightened?Rolex Submariner Date 126610
Diameter: 40.5 mm
Lug to lug: 47.6 mm
Clasp: 18.83 mm
Lug width: 26.7 mm
Thickness: 12 mm
SEL 21mm
Last Link 16,5mm
Here is the difference to 116610
I took my time and measured it with a caliper, so maybe it varies by 0,1 - 0,2 mm
VSF Submariner Date 126610
Diameter: 40,6mm
Lug to lug: 47.6 mm
Clasp: 18.97 mm
Lug width: 26.7 mm
Thickness: 12,80 mm
SEL 21mm
Last Link 16,5mm
Diameter: 40.5 mm
Lug to lug: 47.6 mm
Clasp: 18.83 mm
Lug width: 26.7 mm
Thickness: 12 mm
SEL 21mm
Last Link 16,5mm
Diameter: 40,6mm
Lug to lug: 47.6 mm
Clasp: 18.97 mm
Lug width: 26.7 mm
Thickness: 12,80 mm
SEL 21mm
Last Link 16,5mm
Here we can see it is nearly to gen specification.
Only the thickness is a bit more ( I have the foil on the caseback)
Gesendet von meinem Mi MIX 2S mit Tapatalk
I have the foil on it, as I wroteBezel protector rubber is stiffer than gen, huge tell from across the room. I sometimes do wonder what you guys even care about...
Without foil it's 12,60mm.
Where are talking about 0,6mm that's nothing in real life.
Simply no.Do you visually se any different on case height?
