Raelman007
33
Uhh, he said he bought it from Sead and the thread is about the VSF 126610.
Yes I saw it was from Sead but I'm not sure who he is. I imagine he runs one of the rep websites so wanted to know which website I should go to.
Sorry I wasn't sure if the VSF 126610 is called that or if it actually has a version number as well like other factories.
Thanks
Sent from my RMX2075 using Tapatalk
fatarms
1,900
3,953
Gelena Shitinerand
Thanks
VSF - VS Factory
Sead - Supermirrors in the Trusted Dealer section on this forum
Reactions: YellowFin
Mr.Paneristi
99
51
I think this is the one you mean?
Mr.Paneristi
VSF has done a spectacular job on their 1st crack at the 126610LN/LV! I expected at less a year to see a decent 2020 sub rep to hit the market.
I'm pretty convince on picking up an LN myself.
Any thoughts on what stands out about the VSF that's a flaw?
sukwonee
2,027
6,465
PNW
Amazing. Thanks for your help
There is only one version (officially anyway) of this particular watch from VSF at the moment.
Same for the 116610 (although it is very apparent that there had been several minor updates over the last few months).
Duckber
1,585
869
Beetlejuice! Beetlejuice! Beetlejuice!
I have arrived
Lugs are slightly misshapen, lacks AR coating, and likely has a 116610 dial as opposed to the slightly bigger new dial but that is a subject still up to discussion. End links were also not greatly finished but has been recently updated. All in all it's solid, if you're okay with those flaws go for it!
sukwonee
2,027
6,465
PNW
Man.... VSF looks amazing next to gen (other than the crystal). If I were to nitpick tho, the proportion of the watch itself to bracelet seems slightly bit off. Gen looks slightly larger in size (diameter of the bezel etc) and slimmer in the bracelet area. Maybe also the rehaut thickness seems slightly deeper on the gen optically (perhaps this is due to the crystal). Might just be the angle of the photo taken though. Overall super impressive.
Duckber
1,585
869
You're not wrong, this is likely a shot before they fixed the bracelet taper. They did not update the dial size yet.
dc2_bb6_cu2
544
387
Any idea when gen 126610 crystals are going to be available? I imagine they’re going to fetch a pretty penny.
I don’t have my VSFs on hand (yet, they’re en route), but I am not optimistic. The best cyclops I had previously (prof and ARF) were still quite a ways from gen. I hope to be proven wrong about my assumptions :)
And yes, gen crystals sometime have blue tint so it’s not a “tell”, although when buying gens I look for watches with clear/non-blue AR.
Duckber
1,585
869
So he took it apart and confirmed no AR on the underside of the crystal? Do you know what AR on the underside of a crystal as opposed to the top of the crystal does?
I think you need to understand the difference between lacking and non-existent. Sounds crazy but you can hold both models in hand and play with both in various lighting to see one has a dial that pops more. That's how consumers found out the 41mm has increased the AR, with no crystal removal, believe it or not!
fatarms
1,900
3,953
Gelena Shitinerand
Answer my question. Why does the dial pop more?
