So you mean the clarity of the gen crystal is even better than the VSF? An improvement over VSF? Or the VSFs clarity is noticeable in general?
I would say the clarity difference is not earth and heaven since VSF's crystal is really good already
Vsf crystal is verry good, you will be more than happy with itSo you mean the clarity of the gen crystal is even better than the VSF? An improvement over VSF? Or the VSFs clarity is noticeable in general?
Thanks a lot for those pictures.⭐⭐⭐ 126610LV Crystal + Mov. Service ⭐⭐⭐
Like description, i send my brand new 126610LV to nik for the installation of the Gen crystal and gen clickspring + Servicing the movment to be sure the movment work's perfectly, whater proof test and polishing was not needed because the watch was never used... what to say about nik ? Nice...forum.replica-watch.info
se my work on my vsf, gen crystal is gen m8, you have another look....
yes there is, if you have a VSF you will be happy with it, but if you want to upgrade, you have to change the xtal, only if you change it you will understand that it give you a little bit more....But there is a difference?
it was in the same room at same time, little bit different angle give other colours...but the gen xstal is like a "no xstal" on watch, it's mutch betterThanks a lot for those pictures.
So you say there is a noticeable difference right?
The pictures really look like night and day but i have a feeling it is also due to different ambient lights.
I just installed a gen crystal on one a couple of days ago. Yes the rep cyclops has a bit of distortion when viewed at an angle, but quite honestly you're going to get very little for your money if you go gen. The rep crystal is very clear and side by side I couldn't see any difference between the gen and an identical watch with the rep crystal. IMO you get bragging rights and not a whole lot more. Some might disagree and that's fine. Just my opinion. Cheers.I have a question to all those who installed a gen crystal into the 126610.
Is it just the cyclops (color and distortion) that is improved doing It?
Or is the gen crystal itself even more clear, better quality than the VSF in any way?
I am contemplating that mod but if it is just the cyclops that is getting improved by it, i will keep the stock VSF crystal.
thanks for any input!
I agree. I have gen crystal on one of my daytona(yes its no cyklop on a Daytona i know) and compere to my other Daytona with deep crystal i prefer the deep crystal al day long. Its over hyped with gen crystals. At least on non cyklop crystal. But Im verry happy with my proof crystal on my gmt so i stick to that. And you can get 2 prof crystals and 2 deep crystals for the same amount as 1 gen crystal.I just installed a gen crystal on one a couple of days ago. Yes the rep cyclops has a bit of distortion when viewed at an angle, but quite honestly you're going to get very little for your money if you go gen. The rep crystal is very clear and side by side I couldn't see any difference between the gen and an identical watch with the rep crystal. IMO you get bragging rights and not a whole lot more. Some might disagree and that's fine. Just my opinion. Cheers.
Did you use the gen crystal gasket for installation too? If yes, it pressed fit OK?I just installed a gen crystal on one a couple of days ago. Yes the rep cyclops has a bit of distortion when viewed at an angle, but quite honestly you're going to get very little for your money if you go gen. The rep crystal is very clear and side by side I couldn't see any difference between the gen and an identical watch with the rep crystal. IMO you get bragging rights and not a whole lot more. Some might disagree and that's fine. Just my opinion. Cheers.
Yes this gen crystal gasket fit just fine but sometimes they don’t . They can be too short, too tall, or too tight.Did you use the gen crystal gasket for installation too? If yes, it pressed fit OK?
Thats a question I'd like to knowCyclops, including alignment is well improved. The clarity of the whole crystal is noticeable though yes.
