newonboard
Omega&IWC
452
109
Guys quick question.
Today my VSF 126610LV arrived and I have a small problem - the crown won't screw in all the way - it will slightly cover the rubber - the O-ring and that's it. Has anyone had a similar problem or knows how to solve it?
GGEuroHEADSHOT
599
859
Canada
You need to make sure the crown is in the right position when you screw it in. I’ve had it bind in me when the crown wasn’t sitting correctly, just have to pop out to date setting and then try again.
SS72
2,947
9,973
Australia
Assuming you bought from a TD, I would be touching base with them in the first instance, as that constitutes a fault.
If you're going to engage them, do it immediately and before trying anything else.
That's just what I would do and have done in the past.
Jem93
91
30
Reactions: Kack 13L0CK3R
WatchSmith.US
-- Watchmaker --
Vendor (Watch Repair)
1,289
2,007
Hi,
Can some of the veteran members of this forum / watch help me with my rehaut QC?
https://forum.replica-watch.info/forum/rolex-tudor-replicas/10862142-vsf-126610-rehaut-alignment
I believe that it's not aligned but I'm not completely sure if it's the angle of the picture.
Thank you and sorry for changing direction a bit!
They are rarely or never perfectly aligned and there’s nothing that can be done short of rotating the dial a bit if there’s a bit of play in it. Then your date can be off centered in the date window.
flashu
Tequila Patron
1,638
4,790
Hi,
The answers you received already are good points, most likely in real day to day you’ll never gonna see that slight missalignment.
In the end it is up to you to decide if green or not but there are gens not perfect aligned….
bertieng
1,254
478
Hi,
This misalignment is classic for VSF, or as one of the proof it is genuine VSF, lol.
I never bother or notice such fault with the watch on my wrist.
Just enjoy the masterpiece, mate
