subhunter101
126
13
Fwiw, here’s mine, also with clasp code 1LQ. I wouldn’t say the SELs are sitting above the lugs, but the height along the curved part isn’t uniform. I’m a noob when it comes to subs so I don’t know all the minute details but thought I’d share for comparison.
That’s awful, why would they release them with those end links
muiramas
Aristocrat
18/1/17
6,033
7,927
Really sad to see they messed this up. I wonder if its the case or SEL thats gone wrong though.
I also wonder if the fix is to sand down the bottom lip of the SEL where it meets the case which would alow it to rotate downwards. That way you’re not messing around with the visible area.
Reactions: KJ2020
36,276
74,246
Nothing wrong with these springbars - straight, solid and locked in tight.
To get the bracelet side of the SEL lower through SEL rotation would require the lower lip to rise a little. This will also raise the top of the SEL where it meets the case. Usually there is a room to do this under the bezel but often this rotation will also pull the top of the SEL away from the case.
I've been able to accomplish this on a hollow end link but only because you can then bend the top of the SEL back toward the case, essentially making it less tall but slightly longer. As Triplock mentioned, filing or sanding the top of the SEL is really the best solution, though it is quite challenging not to mention labor intensive. It's also hard to regain uniform brushing that results in a nice reflection line across the SEL.
36,276
74,246
Indeed bro, the pre-raid bracelet fit was pretty nearly perfect. My guess is it's a bracelet batch issue.
Reactions: Tijdwijzer
Carrick1
312
104
Hi all,
I would appreciate your help , can you see the Sel gap in the bottom right hand corner or is it my eyes looking for trouble. And again I have seen so many posts and numbers and what to look for I snow blind, but are these number in general ok. Hope I not breaking any rules. Thanks
StreetFighter
Insert Coin
4/9/20
2,880
3,466
Anyone else noticed the two different stickers styles on the SEL's on these recent QC's? Two different suppliers, 2 different qualities?
keisuke_z
505
303
Interestingly, here’s how it looks on my wrist - it seems to sit a hair lower against the lugs.
*edit* --> just to clarify, I'm not nitpicking at all here, just providing some photos for folks to compare against since it seemed like people were wondering. Couldn't be happier with this rep!
Reactions: GottaHave
keisuke_z
505
303
I seriously don't mean to be rude but you're worrying over absolutely nothing here.
It AIN'T a Rolex PLUS it's still better than 98% of any watch out there.
Oh, I'm not worried at all - just sharing for folks who were doing comparisons. I'm quite happy with mine!
WatchSmith.US
1,298
2,037
I would like to buy any broken, non-working VS3235 movement for a special project.
Delifisek53
Hi everyone,
This is my VSF 126610LV as well. :( The bezel finally popped off ( dont know why ) and all the springs and stuff are missing for me now.
I asked my TD about the parts but still can’t get an answer.
Someone had the same problem and found the solution will be great for me. :(
Thnx.
eazye
1,334
261
Hi all,
Trash. Send it back
Reactions: De Kev
stance
105
208
Singapore
Hi everyone,
Thnx.
Saw a few in ali. Can try searching under Bezel Inner Case Click Spring Steel Ball. However I do not know if it fits 126610.
Sent from the RWI mobile app
subhunter101
126
13
Has anybody had issues with fading bezel on the 126610? Mine seems to have dulled a bit, it doesn’t have a bright luster like it should
