IntenseImage
253
263
I got a good one (I think hahaha)
japer
818
776
My watch stopped running. With a huge wrist swing the watch starts running again for about 48 hours and stops again. Then the process repeats: huge swing it starts running again (accurately). Seems that normal walking isn't enough to energize it. Any experts who could chime in? what could it be? Let's see how long it runs for now. Help is much appreciated.
Reactions: Jayalvin777
bertieng
1,274
486
This is worrying. It seems that the problems of the VS3235 are starting to emerge. Wondering if it would be a better bet to put a VR3135 into the watch instead. Then do they share the same dial feet positions?
Reactions: Rel
bertieng
1,274
486
Got a reply from TD about QC as follows.
"unluckily amplitudes from this batch are most between 210-250 ,it's hard to find one with higher amplitude .
We've kept the watch working for more than 36hrs to make sure therre is no reserve issue :)"
Does this sound normal and acceptable?
bertieng
1,274
486
bertieng
1,274
486
TD replied this.
Does it sound normal and ok?
Rehaut19
INMATE
30/12/20
517
332
this mean that the movements need service?
muiramas
Aristocrat
18/1/17
6,105
8,131
Sad to hear this - mine is still running like a champ, but certainly making me re-think next purchases.
I assume this is affecting Date Justs as well?
WatchSmith.US
1,307
2,060
I have a LN and LV. One has a 270+ amplitude and the other is around 240. Both keep perfect time and the one I tested had 65+ hours power reserve. Also, both have gen balance and bridge.
misiekped might have info on amplitude.
bertieng
1,274
486
This is interesting. So even with the gen. full balance setup installed, the amplitude can still have a rather big variance in the VS3235.
This inconsistency can mean the VS3235 is not yet as maturely constructed as the VR3135?
Perhaps I should just accept the watch with the current low amplitude config. then.
WatchSmith.US
1,307
2,060
There are a few things that can affect amplitude. Mainspring, dirt, inadequate lube, balance endshake. I wonder if my low amplitude movement will receive a boost with a service. I would assume it would. We have to remember that rep companies don't have Rolex trained watchmakers assembling movements, and they lack quality control that Swiss companies have, so there are bound to be some that are improperly lubricated and assembled. On one of mine I examined the VS balance jewel and it was correctly lubed which is good, but I haven't torn it down to examine the rest of the movement. Getting it serviced is obviously cheap insurance.
Rehaut19
INMATE
30/12/20
517
332
Caliber 3235 does not have the characteristics of the caliber 3135. The amplitude of the caliber 3235 less.
Cal. 3235:
Lift angle - 52
Amplitude at full wind -- 260_270 max
The mechanism is checked after 24 hours. The amplitude must not be less than 210. Accuracy on the second day -- -3/+5 s/d.
Reactions: WatchSmith.US
gindiesel
226
141
Canada
What happens when you wind it?
