- 28/5/11
- 1,434
- 1
- 0
Sean takes the 3135 or eta 2892-a2
2824 also possible but better not
because of stem height. Only the Sean case is 100% spot on in terms of crown height with the Gen.
Since it does not make any sense to put a gen movement in a fake case, the only choice is to put a 3135 clone that has to be bought together with a full watch, this movement, as I know it, is still not available as a spare part.
Sent.
Not entirely true.
I have a case that's perfect with crown height as I've dropped a gen 3035 mvt and dial in it...and it's neither a TC or a sean case
Better than "almost" anything I've ever seenYES..It is more compared to the gen than anything you know
Fitting a 3135 into a case designed for a 3035 is possible.Why is it that on the Sean site it says his case can take a 3035 and a 3135 :s which one does it fit, it can't fit both. Looks like I might sell my TC then!
But a 3035 will "not" fit a case designed for a 3135.
The 3035 is a thicker mvt. (hence the shallower rehaut and deeper case back.
A gen bezel ring will not fit a TC retaining ring without modding the retaining ring.There was a similar build over at RWG
A 3135 is bucks, like 1500-2000. Ridiculous to fork down that much money and it is still a rep. You rbuild will cost 3000+. Keep it real, my franken is at 1000 cost and that is nucking futs if you think about it but come on, who is going to pull your crown and wind your watch.
If you have your heart set on that project, I would use a sean case in all honesty.
BTW to get your list has
aftermarket crystal retainer, bezel spring, click spring
If you bought a v4, it came with a bezel and crystal retainer etc
At least mine doesn't.
