Rolex Super Sea-Dweller Review / Franken Project Q5?
Q5?
15,273
I fixed my clasp! It was easy.
I took the link apart and replaced the side that had the broken screw.
:thumbsup:
Q5?
15,273
I just had her tested without doing the epoxy mod on the HEV.
I do recommend testing your own. Mine might be a lucky. :)
Q5?
15,273
Thanks tommy! It passed the pool test today also :)
Americano
10/5/10
61
Curiosity
A curiosity. Does the valve works in th:headdesk:ese watch?
Q5?
15,273
It does not work as it should. I didn't seal the HEV and it is water tight though.:wacko:
If you own one, make sure to have it tested if you want to get it wet.
rsh
Put Some Respect On My Name
3/4/10
5,137
Does the valve look like the one on the GEN ?
Spirit
Rolex Connoisseur
25/8/06
3,625
51
Yes, it does.
...It´s the latest model of the Sea-Dweller tho..the one without lugholes, that came with the Titanium He Valve...the earlier versions (until 2002) doesn´t have Titanium ones, just steel ones, and also have lugholes.
GEN for reference:
Cheers,
Spirit.
JellyJoe
28/9/09
4,098
23
You wont need a working Hev in the water, mate. Infact, unless you are a saturation diver using decompression chambers you'll never use a Hev at all.
countit
407
Guys-
Can you give me advice on this watch. Is there a newer, more updated version than this one from Timeshops? Or, is this the best that is out there right now?
Thank you for the advice.
Q5?
15,273
Just sent her to Jackjo for CG trim and WM insert shave.
I'll post pics when it's back. :q5:
ostatecowboy67
120
Q5? I was in contact with Mark last night to order my twin watch like yours, and I asked him what gauage the stainless steel was. He said that he didn't know. Do you happen to know which gauge it is? Also, I asked about the 100m waterproof listed on the site and he said that the factory told him that, but they don't recommend swimming in it or diving in it. Did you have to do anything to waterproof your model? Also, do you know if there is any difference between the watch parts on the clone 2836 and 21J except the movements (such as band, clasp, etc)? Thanks
JellyJoe
28/9/09
4,098
23
Hands and dial may change from 21j and 2836. Stem as well, but you wont see that.
Basic waterproofing is greasing all gaskets and O-rings and tightening caseback with a proper Bergeon wrench. As for the Hev some apparently hold decently, but I wouldnt bet a used match on diving unless you seal it with Epoxy.
fleadepot
475
11
Hampshire
Really cool SD :)
Sorry for a little hijack :)
Is there anything to do with the crystall to make a watch like this water tight? I see everyone is talking about greasing the seals and epoxy sealing the HeV but no one mentioned the crystal itself.
Should the crystal be checked with the press and eventually pressed in if needed? Or eventually taken out, glued in with UV glue and sealed around with something?
JellyJoe
28/9/09
4,098
23
Really cool SD :)
If you have experience and wanna be extra safe with your crystal, some crystal adhesive (UV or not) would be better, but dont spill or overdose it and get the right one. Then install it evenly with a crystal press.
http://www.cousinsuk.com/catalog/7/1119/1349.aspx
Q5, if you need noob links or screws tell me, I might have something. In case I'll just throw you the stuff, mate.
Q5?
15,273
My Jacjo modded SD is 20min away in SF. I might get it today.
R2 sent him a Gen crown to put on for me. :)
Found this pic of the Gen SD in one of Jacjo's threads. Nice crown.
rsh
3/4/10
5,137
I noticed the nooby sub crown does not fit the crown tube, the threads are wider on this SD rep, did the gen crown fit or did the tube need to be replaced as well ?
Q5?
15,273
It arrived today.
The Gen crown screws down perfectly on the rep tube.
Mods done by Jackjo:
WM insert sanded
CG's shaved
Gen crown installed
Bracelet polished an lubed
JC7
15/6/10
3,978
12
very jealous Q.. crystal is sickening.
