Panerai PAM318/005k from hublot factory crown problem
Sgn_vn
300
Here one more.
ebzen02
3,169
2,590
You should charge for this mod.. You could make some nice change.. ;)
Sgn_vn
300
how about$$$$$$$$$$$$$$$$$1, seriously darth give it a try bro.
sportvega
155
Here is what I've done. This is not a tutorial. It is simply what I've done. I am not responsible if your 005 become pinball parts. hope this helps.
Remove caseback
remove crown guard
Unscrew crown screw a few turns till crown is loose and able to pull out. DO NOT UNSCREW FULLY!
Take the bitch out
Add rubber o-rings (i took these off of a spare crown I had laying around)
The o-rings stacked (depending on how much you dremel the crown is how many orings you need.
The crown dremeled
Insert crown and tighten screw.
The Finish product.
money shot?
How did I do?
Member X
1,289
11
If you can tell a low beat 6497 against a high beat 6497 on the wrist, you're a better man than me... :lol:
supermanx
2,577
You can hear the low beat across the room :p
Sent from my PC36100 using Tapatalk
sportvega
155
005 comes with a low beat movements. i swapped this with a 111j high movement to bring that bitch up to a superrep status. i wished they did come with better movement.
Mambo
1,652
When doing a movement swap do you need to swap the stem/crown as well ?? or are all 6497 stems interchangeable ...
I would like to put my 111J movement in my 177L ...
Thanks ... any input is appreciated :)
supermanx
2,577
No issue with the crown/stem. Just put a high beat in my 219 today. Seed said he had some problems with the hands on the hublot factory's but so I bought a 111 set but didn't need it.
Now to find another high beat for my 177.
Darthmemnoch
648
17
Looks good. For those of us with a much smaller parts bin, where can we find the necessary o rings....
...and ps... anyone want to sell a fixed crown?
Mambo
1,652
Thanks for the info :) ....
