Panerai PAM318/005k from hublot factory crown problem
davemul
163
has anyone got a clear picture of what the crown wheel issue looks like before beign fixed. Im new to these and fail to see any differences...!?
davemul
163
aaah I see now! thanks v much. The wheel is a bit tight to the left isnt it!
Mambo
1,652
Yes, a bit too close to the case .... but it's fixable ;)
sead1999
Trusted Dealer
Trusted Dealer
28/2/07
2,903
675
here again
if u do amovement swap be careful u might not need new hands or maybe u might who want a crown mod
send me the crown and cg here i will fix those for a small fee
Darthmemnoch
648
17
The reason why I wanted to pay someone to fix this for me is the prohibitive cost of the dremel vs paying someone like 10 dollars
supermanx
2,577
I personally would leave it as is, seen quite a few people "over" fix, and more then a couple gens with crowns VERY close to the case.
Darthmemnoch
648
17
See mine...
Darthmemnoch
648
17
I am going to try this with a new T-48 crown after over dremeling and ruining my first crown. Can I ask what was the vice in the picture that you are using to hold your crown?
Also, where can I buy the right O ring?
here are the pictures. I double crown gaskets
yanher
10/3/11
I use the 111J CG & Crown can easy to fix this problem.
bravo9
Any leads as to where I can buy a crown and cg to make my crown a bit more spaced from the case? I have a 005 and it's a bit tight :(
