DEFINITELY stay away from a non-TD, and I wouldn't go with a Silix case either. I've been researching this project a lot since March and they're not a great option because of the weird non-Gen spec construction.
You can use a Cartel 1655 and have someone thin it out and grind down the crown guards, or look into a Yuki or MQ case. Either way this isn't a cheap build if you really want to "do this right" but if you've already got the NDT I'd say do it right.
I learned this the hard way on a recent Tudor Snowflake build. I had spent almost half the cost of a gen between buying a selling "budget" parts I thought would get the job done and I wasn't even close to finished.
Sent from the
RWI mobile app
