Hybrid build: PF case, 3K movement, PPF dial and hands
THXuk
1,492
846
London
I know, but the PF still need a lot of work, slimming, bevels, cutout at the crown ect.
Cosmo is modding the PPF, with a reshape of the bezel, and shortening the crown. It just seems like less overall work, and you don’t have to source both a PF and PPF dial/hands
But would the 3K movement fit inside the PPF case?
MasterWatch
Master of None
2,561
709
I don’t quite follow you on the bezel, where do you see it as being to wide after the reshape?
I see a very slight difference on the crown guard between a stock PPF and my own hybrid, but we are talking a very slight difference
I don't want to hijack this thread and continue this discussion. So I'll PM you.
Reactions: 2841
srhoque
3,259
2,467
Amazing work legend . As of now, this combo seems to be the best clone money can buy.
Based on your experience and after service/regulation - do you think the 3K 324 clone will be like the Miyota (which are work horses in my opinion) in terms of long term reliability.
legend
The RWI Dragon
✮✮ Lifetime Patron ✮✮
64,291
82,784
Where I need to be.
Thank you S. I will compare the 324 clone to the 4130 clone and say that if 4130 clone is a 90/100 after service, this one is about the same in terms of reliability. The quality of the parts isn’t the best and the alignment between parts can be improved with an overhaul.
DerpyOfficer
DerpiestOfWatchmakers
482
305
legend Amazing work on this, would you mind breaking down what was the end combination of parts used for this build? I have a spare PF case and a 3KFv1 movement. And might take up this challenge myself.
THXuk
1,492
846
London
legend
Amazing build but out of my budget, do you think the 3k movement can fit in the ppf case?
legend
The RWI Dragon
64,291
82,784
Where I need to be.
legend
Yes it will. The ppf and pf case are different but in either case the 3k movement can be made to fit with proper machining work.
Reactions: Allure
legend
The RWI Dragon
64,291
82,784
Where I need to be.
I used the PF case, 3k v2 movement and PPF dial and hands sir.
Reactions: Allure and tamomota
BIONONE
3,720
3,034
PPF dial and hands
outstanding project as always, sir.
Did the PPF hands fit without any modification?
I was thinking about adding a 324 SC clone to a ZF calatrava based on the same 9015 as the PPF.
Looking forward to see some more insights of the other implantations ;)
