frank134 said:I have a problem that the extension dosent go all the way down (on my Omega Planet Ocean):
Its very difficult to see but the only thing I can think of are the little "bulges" in each side:
I tried with a plier but it seems not to press them inwards.
EDIT: Comared to the pic in the beginning of the thread the space in between the extension seems very narrow on my pic - dont know if it is the exact same model:
time_bandit said:This is a common problem with the Omega reps but fortunately it is an easy fix.
The way the clasp SHOULD work is a spring in the clasp snaps around both sides of this piece.
I Will try tomorow but it was a great howto so it would be nice to have the pictures if someone CAN help.frank134 said:If the bracelet "clicks off by itself" its because the spring is too wide. Just take a small screwdriver and force the two sides of the spring together. Then it will become tight enough to keep the clasp in place.
No there is not... they are gone forever...So is there any way for those photos to be replaced? Since it seems to be such a common problem, perhaps another member could post a new series of photos?
I need help with mine. The original post pics are all gone. I tried to fix it without taking it apart but to no avail.
Also the last link next to the part of the clasp where it opens flops down perpendicular. I need a fix for that too. It does that on both of my PO omega watches. Any help is kindly appreciated for these two issues. This watch is going to get very very minimal wrist time so that it won't fall on the floor.
I flattened the piece with the "mushroom" pin ever-so-slightly (in the area shown by the arrow) on mine. This makes the clasp close nice and tight which keeps those endlinks from (annoyingly) flipping over.
Be carfeul not to bend the portion that has been ground out to go over the crossbar, as it will likely snap on you.
how do you go about flattening that?
On mine, I replaced the pin on that link. I was blown away that I could push the pin that was in there out with my fingers and without a tool!! So it had to go. I put a 0.039" pin in its place.
Oh I see what you are saying, that actual arm. Yeah that won't work for me since I already put the correct size pin. I'll double check though. I think I may still have to modify the spring and it looks like I have to remove two pins in order to get that out. Since the photos are gone I'll just have to use judgement hopefully it is simple. It should be. Most things on this watch are.
any way to get new pic? is this not needed on the UPO's
