- 30/10/06
- 114
- 0
- 0
This is a common problem with the Omega reps but fortunately it is an easy fix.
The way the clasp SHOULD work is a spring in the clasp snaps around both sides of this piece.
The problem is due to the spring in the clasp is often mis-shaped so either only one side of the spring connects or the tension is too weak.
To fix the problem the first step is to dis-assemble the locking mechanism by pushing out the pin indicated below:
Here are all the parts. Be careful not to lose the sleeve that fits over the pin, it is what locks the pin in place.
This is the root of the problem. A badly formed spring.
Remove the spring from the clasp using needle nose pliers. Again, be careful not to loose the two buttons on either end of the spring.
Once you have removed the spring you will need to reshape the spring by bending it so it looks like the example below. Note how it angles up so that the spring presses up against the cover.
All that is left now is to re-assemble the parts. There are small holes drilled into the buttons that the ends of the spring fit into.
After re-assembly - note how both sides of the spring are now visible and sit higher in the clasp.
The bracelet now closes with a very satisfying SNAP
Adjusting the DIVERS EXTENSION
If the lip is too large you can try carefully squeezing it back with plyers or filing it down.
Fortunately this piece is hidden so it won't show if you scratch something.
DISCLAIMER
Please make sure that you understand that the information provided here is being provided freely, and that no kind of agreement or contract is created. The material is informational only. I can not and will not be held responsible for damages to or resulting from anything that you may decide to do to your watch.
![step_1.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_1.jpg)
![step_2.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_2.jpg)
![step_3.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_3.jpg)
![step_4.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_4.jpg)
![step_5.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_5.jpg)
![step_6.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_6.jpg)
![step_7.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_7.jpg)
![step_8.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_8.jpg)
![step_9.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_9.jpg)
![step_10.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_10.jpg)
![step_11.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_11.jpg)
![step_12.jpg](http://i148.photobucket.com/albums/s21/time_bandit_photos/step_12.jpg)
DISCLAIMER
