DIY Serial etching - Work in progress
Megahz1
Vintage lover
6/5/18
91
356
53
Hi everyone,
I was bothered by the ugly serials that come with "cheap" cases (JKF, Raffles, etc...), but unfortunately I do not have access to a CNC nor to a pantograph engraver.
I know that there are members on the forum that do amazing serial engravings, but I prefer experimenting and doing this type of stuff by myself.
After having a look at this great article https://www.chrono-shop.net/en/blog/rolex-serial-numbers-find-your-rolex-production-date--n23 I decided to create my own design on Inkscape using images of period correct watches matching my builds (currently planning on doing this on 5513 and 1016 builds).
I am not yet ready to do this on an actual case, but for the moment I did some testing on a piece of SS. The process is done using PCB photosensitive film and saltwater etching and I think the results are pretty good considering how tiny the letters/numbers are.
Here some pics for you to judge!
Apart from the top portion of the letter "A" which should be flat, I think the results are good; remember that these are less than 20mm wide and look more consistent IRL.
Let me know what you think and if I should change something or if you see something wrong other than the letter "A", I am currently testing so your feedback is appreciated.
I will post progress and results as soon as I perfect the technique!
Maximillian
3,170
6,184
Böhmerwald
Hi everyone,
Nice work! How big is the size? I mean what is the true size of the etching you did on the SS?
manodeoro
DO NOT TRADE WITH ME
4,013
2,661
@Megahz1 ... excellent job 👍
What's nice with salted water etching is the the result looks much close to the gen than the laser etching.
I've engraved watches using that method and from my experience the result you got is close to perfect 👌
Megahz1
Vintage lover
6/5/18
91
356
53
Today I tried to etch the case and the process was pretty tough tbh as it took me multiple attempts to align everything and etch with such small details. One thing is doing the etching on a plain surface with no limitations (lugs) and another thing is actually doing it on a watch...
I also had a problem where I did not etch the letter "R" properly and I had to add it later, so it is not 100% aligned.
Overall it turned out ok and I think it is better than the wrong reference that was etched before. It is a starting point and I am sure that with enough practice I will be able to improve the outcome; I will post progress.
manodeoro
4,013
2,661
@Megahz1 ... really great job ...
I've engraved several cases using the same technique and I know it's not as easy as it seems so congrats !!!
BTW ... I used an old 6V battery charger as an electrical source but it's showing signs of weakness and I'm going to have to replace it.
Given the quality of your engravings, I'd really like to know what source you use ... charger or transformer ... if you don't mind sharing the info.
