Daytona 116519 Beach build help :)
2841
Daytona Hoarder
2,242
2,159
I think the old Noob cases did this correctly? But none of the current factories do it this way AFAIK.
if we wanna be REAL period correct, there are 2 paths
1. MK1 dial, old school case (like your pic), and old style clasp
2. MK2 dial, new style case with double lugholes and new style clasp :)
Reactions: Autobús
2841
Daytona Hoarder
2,242
2,159
yes im afraid so.... do you recommend any specific TD to buy the case and bezel from? dont want to buy another daytona before my panda delivers LOL
If you want just the parts, it depends on your relationship with the TD, I mostly deal with Jtime & Ctime.
But I would just get the whole watch, since you are only changing the dial and strap. Any CF 116519 on rubber (and steel bezel) would be a good base
2841
Daytona Hoarder
2,242
2,159
If you're after a bracelet or strap build.
This is a 116509 vs 116519 case. Note the difference in lug hole placement.
I where under the impression that you could put a bracelet on a 116519 case. Is the above both from CF?
2841
Daytona Hoarder
2,242
2,159
Here is a buff dial MK2. It has a weird marvel/stone effect that’s not correct, and the subdials are to big (Inner diameter)
gen below
2841
Daytona Hoarder
2,242
2,159
In the past i had bought these.
These have pretty good quality and font, but not cheap unfortnually and not easy to find
Any news on this dial bud?
Day2dayVersatileLover
35
eric over at geek time said the factory wouldnt sell him parts individually + i saw that tungsten 116519 case in the other forum that interests me!
2841
Daytona Hoarder
2,242
2,159
I found a near perfect dial, don’t think it’s going to get any better then this.
Ill order one, and give you guys a mini review when it shows up
35
at this point screw it ill get it too, pls share the source... do they also carry the other colors?
2841
Daytona Hoarder
2,242
2,159
On closer examination the hourmarkers are to big. X is touching the subdial :) Gen on the right
Ill keep looking
Reactions: tomriddle
tomriddle
667
923
since you're going for the strap.. one huge, HUGE tip i can offer is make sure the strap is made/done by someone who knows the dial and can match the hue/turqoise exactly. it makes a huge difference in its presentation.
look at my own beach.. this was right after it was finished.
I ruined the strap so i had to get a replacement and well.. it doesn't quite, "match up".. i can most definitely tell the difference.
i'm not sure if the person who built my beach knew the one who made the strap but basically i can't get it now because they're retired :( so i have to "settle" for this replacement strap i sourced off of italy. maybe in time the turqoise would fade to match the dial :) eventually.. maybe.
there's a reason you seldom see the Beachtona and that's cuz it's hard to match up all the pieces required to make the recipe work.
tomriddle
667
923
Ill keep looking
I wasn't going to say nothing :) but i was thinking, "he doesn't see how chunky those are?" :p
aHero
Watch Bro
4,102
5,929
i thought those looks a bit big but figured you saw it :)
lukko
3,640
866
No yet mate, unfortunally actually i’m in vacation in Japan :)
When i return back to normal life and i’ve time i go to the local watchmaker and i’ll ask him :)
Reactions: millklones
2841
Daytona Hoarder
2,242
2,159
No rush, and enjoy your vacation:)
lukko
3,640
866
Hi mate, i’ve asked him but unfortunally he said to me that the last time he order those dials aren’t available againg with that quality. He show me another quailty, but unfortunally aren’t the same
