Correct tap for 7mm tube
Fraist
89
50
Keep in mind you want to go deep enough to seat the tube deep enough.
If you don’t, the crown will stick out from the case and look off.
I don’t have a set depth, but rather I test the tube frequently until it’s at the depth that allows the crown to seat properly.
Here’s one I just did. 120 degree 4mm chamfer.
Thank you for the picture. The sealing needs a lot of pressure to be watertight?
Can you also share a picture without the tube to see the opening ?
Zeta7
1,148
1,171
What case is that a clean or BP?
PsychoTee16
-- Watchmaker --
Vendor (Watch Repair)
1,266
1,033
Louisiana
Don’t torque it too much. You’ll strip the internal ribs used for your key tool.
Pic of a gmt I did.
Reactions: Fraist
drvintage
Vendor (Probationary)
791
1,948
GER
Hey guys, do someone know the crown thread measurements?
MDswimmer
33
31
Maryland
If there are more people interested i believe makes sense to place an order.
Hi Fraist, did you still need 6 people to buy in the US For the 3.0 X .30 tap? And I have a case that 3.0 X .35 do I just run the 3.0 X .30 tap to retread?
MDswimmer
33
31
Maryland
As you all have found out, nearly every tap offered on the market for these tubes is indeed incorrect. People will say they work, but they don’t.
The tubes get way too tight after a few turns on the wrench.
The correct tap size is : M3.05x.30-4H
Daytona pushers on the other had, do have options available on the market. That tap size is M2.5x.25, and can be found on CousinsUK.
I’ve had these made via the same USA manufacture as listed above and they turned out great.
Gen tubes thread in with no issues.
Couple pics
Couple pics
When retaping from m3x.35 threads to m3x.30 is there anything needs to be done?
Karbon74
Pika Factory
12,038
25,064
EU - Kalos Region
Guys
I need some advice
When you tap, do you hold the case in hand or do you secure it in a vice and table?
HulkyGalore
405
515
Reactions: Karbon74
ward1991
3,447
3,442
Rust Belt
A vise is probably the best advice, but honestly, I've done so many in hand that I probably would never switch. I can only recall one where it was cockeyed a little but I couldn't really tell by the time I got it all together.
I like to be sure to back the tap out if I feel any resistance to clear shavings
I also ream/drill tube holes to larger diameters with my cordless drill, with the case on the edge of the table🦸‍♂️
I also use 45 degree countersinking bits in my cordless too when tubes need to be recessed, but it only takes 1 quick squeeze to accomplish.
Reactions: Karbon74
Labedudel
115
75
i am 100% sure I used the correct tap. I have tested 3 different tap sets the last months. With all I have the same problem.
The taps that i used above 3x0.35 and 3x0.25
For the right drill for your thread, here as an example M4, you have to calculate the pitch 0.7 (thread pitch). Here the drill would be a 3.3mm drill, the right one for pre-drilling, then you could cut your M4 thread. There are also tables for this, just google it.
What else should be taken into account is not to confuse a thread cutter with a thread former. I hope I could be of some help.
Zeta7
1,148
1,171
Great information @Karbon74. Thanks for wising us up to the right tool and where to get it from.
Reactions: Karbon74
