Correct tap for 7mm tube
Fraist
89
50
I am trying for almost 3 months now to tap a case to install a gen 7 mm (24-7030) tube Without success.
The problem is that i am not able to find the correct tap.
I have tried the 3x0.35 and the 3x0.25 from different suppliers and qualities but the threads were not correct.
I believe the correct is the 3x0.30 but i am not able to find such a tap to test. Is anyone knows where to find such a tap?
Thanks
Reactions: Caboose
ward1991
Looking for Noob 116610 sub bracelet💚
3,394
3,318
Rust Belt
What size bit have you pre-drilled your hole with?
Looking for you still, heres some relevant info:
Reactions: Karbon74
Fraist
89
50
I used both 2.7 mm and 2.65 mm drill. Both had the same issue. The problem is the tube goes inside for two or three turns and then stuck. I will try to make a closeup picture of the tap and the tube thread to see the differences in the thread.
ward1991
3,394
3,318
Rust Belt
Okay, also, do you have more than one tube to rule out that it may be a QC issue with your current tube?
Sorry for obvious questions, are you running the tap deep enough? I go all the way through.
Reactions: Karbon74
Karbon74
Pika Factory
11,889
24,576
EU - Kalos Region
I would also advise to buy a replica (24-7030) on AliExpress and try out the retap threading
Use the opportunity to take good measurements of the thread width’using a micrometer
From what I read, the issue is either there is a metal shaving that has melt-welded in the hole, or the thread width being used is not the right one vs the tube
Fraist
89
50
I have a gen tube and a swiss made aftermarket from cousins and both have the same issue.
I was also thinking to buy a athaya tube that is 3x0.35 but unfortunately is not compatible with gen crown.
Fraist
89
50
I used quality made in Germany taps. So the treads are correct.
please check the 3x0.35 tap in comparison to the tube. Only three threads are ok then the thread does not fit
the 3x0.0.25 is also too small so I believe the 3x0.3 is the correct
ward1991
3,394
3,318
Rust Belt
Let Me Think What GIF by GritTV
Reactions: Karbon74
Karbon74
Pika Factory
11,889
24,576
EU - Kalos Region
In the first pic, the pitch of the tool look bigger that the tube
One thing I did once (so do at your own risk 😅) is to use the other tube( the rep) to force the threading…
Reactions: W47chl0v3r
tbandy
665
537
I just Checked my taps (Set of three, one to start, then the second and the third one for finish)
It shows M3X0,35 HSS
That is what I use and never had a problem.
Reactions: ward1991
ward1991
3,394
3,318
Rust Belt
I agree about the pitch.
3x.03 tap is not listed on interweb anywhere that I can see. Might need a custom tap made.
But yeah I wouldn't have bothered this long with it, I would have forced it in there with some loctite or epoxy since it would F threads up anyways. Sucks for long term servicing. You'd have to laser weld it and start over.
tbandy
665
537
I wonder why you are having problems I just double check the pitch is 0.35
Reactions: Caboose
Karbon74
Pika Factory
11,889
24,576
EU - Kalos Region
Respectfully, I am looking at this again.
Are you sure you are using a m3x0.35 ?
Because this looks like a metric, so M3x0.5
Which would 100% explain your symptom
Reactions: ward1991
tbandy
665
537
just check the Esslinger.com link it confirm it's M3X0.35
Fraist
89
50
i am 100% sure I used the correct tap. I have tested 3 different tap sets the last months. With all I have the same problem.
The taps that i used above 3x0.35 and 3x0.25
