BP Sea-Dweller 16600 re-release with VR3135
kiasunkiasi
376
385
Malaysia
great watch ... makes me missing my first ever gen 16600 ...
how can we get it to look a bit used? it looks too shiny for long discontinued 16600 ...
flashu
Tequila Patron
1,646
4,822
You can tell that’s NOS 🤣
There is at least one thread here on RWI , if I remember correctly in Modification section
I intend to work a little on it but still reading before proceed
fra44
47
21
Watch is 15.48mm thick, 1mm + compared with gen, this probably because of rep thicker crystal I guess
Will this take gen crystal?
Since you have the caliper, do you know if the diameter of the 16600 is an exact 40mm? Thank you!
flashu
Tequila Patron
1,646
4,822
16600 vs 16610 / both bp/ same “batch” (Jan 2024) :D
I didn’t had my glasses on to put it micro nanometer exactly on the bezel teeth but take plus / minus 0.10 - 0.15mm and that’s it
Dizzy
Advisor - Vintage Rolex
3,589
637
Western Canada
The previous version of the BP 16600 would not take a Gen spec crystal. It can be done with a little machining work and or a whole lot of UV glue. I haven’t seen any info on someone taking one of these new ones apart Yet.
Reactions: flashu
flashu
Tequila Patron
1,646
4,822
Yes, I have asked the same question if can take gen crystal but no one answered, will be great to see if we can have gen crystal + gen insert
Im not moving in unless some experts tell us if yes or not :)
Reactions: fra44
fra44
47
21
Thank you very much!!
Reactions: flashu
flashu
Tequila Patron
1,646
4,822
Dizzy
3,589
637
Western Canada
I seriously doubt it. They still haven’t switched to a genuine style bezel assembly. The last version of this watch wouldn’t take a genuine crystal either. you can modify the case to make it work but that’s probably beyond the ability of the average person here.
Reactions: flashu
flashu
Tequila Patron
1,646
4,822
Thank you for clarification, I don't have the skills to do it by myself so for now will leave it as it is, really like this 16600
flashu
Tequila Patron
1,646
4,822
Nope, it is a light reflection from the steel grill
scotjackson
45
This new breed has the bezel hold from a wire and a really big Cklickspring Wire. Bracelet is wrong, Crystal shape wrong and Caseback engravings are too smal!☝️
hi tribal, do you think they are using the same case as previous generations?
