only good thing about this watch are: BEZEL AND DIAL (obviously the famous VR movement) everything else is to be thrown in the toilet
Remove the bezel. And put the ring down, and instal everything again.
Its easy but need take care.
Enviado de meu SM-G975F usando o Tapatalk
So, it looks like this is a very common issue with the ZZF bracelet. Same for mine. My advice is to soak the bracelet overnight in WD40 solution. Then turn the screwhead anti clockwise and the closewise repeatedly. Do this procedure till the screws loosen off. A good screw driver is also essential.They sent mine 14-04. So it took exactly one month. Can't get the screws out though, ruined screws and a big scratch on the side of the bracelet. Any tips?
That's a bullshit bro
No such issue though with ARF bracelet at ALL. That is why I love the ARF bracelets.
Really? Enlightnen us.
Ahahahha what do you want to hear? You don't get it yourself? Bracelet is good and has a very nice finish sels on most examples (mine not) are perfect with no gaps and perfect recession like gen do you know how much that tight tolerances costs? We are talking about a 500$ watch with one of the best clone movement you can get. Dial is good i ve seen mine go black and green at the same time even under sunlight.. bezel its a work of art almost indistinguishable from the gen even side by side. markers very good and shaped like gen, lume very good too. Its quicker to tell his flaws that are only lugs shape, fat cgs, the "x", pearl color but no one of these its an easy tell. Imo if they fix the pearl this watch with a gen xtal and dw its a nwbig
if you don't understand that the case and the bracelet are cheap really, then withdraw this hobby is not for you
