Best Pam 438 Tuttonero late 2015
ALE7575
Section Mod
19,845
419
The best versions are from KW-V6Fac
There are two interesting models:
With A7750 NON -inverted and with Seagull NON-inverted
I like seagull because the accuracy and the price, but there are lastly a lot of A7750 lovers.
UP TO YOU
ALE
You have all updated info in PAM GUIDE
zxcv81
168
UP TO YOU
ALE
Thank You, Ale!
Can you link me the addresses of online stores that sell the two best models that you have recommended to me?
Thank you!
Norrie
2,063
64
Thank You, Ale!
Thank you!
Go to the trusted dealers section and choose one and get in touch. They can all get the same product.
zxcv81
168
Ok!
The two PAM from Pure Time (the links that I posted above) are both KW-V6Fac, right?
The seagull is one that costs less. Right?
Thanks!
ALE7575
Section Mod
19,845
419
Thank You, Ale!
Thank you!
You have in PAM GUIDE the links ordered by models
ALE
zxcv81
168
Hello guys! Between two or three days I will order the Pam.
Some questions:
Can I post here the QC pictures?
I saw that in the back of the PAM there is a charge indicator. Does it work?
There are differences visible to the naked eye with the GEN?
zxcv81
168
Some questions:
Help! :)
Maraach
330
Generally QC pics are not allowed but there are some exceptions.. there is a thread for the 438 to do so i believe.
The Power reserve indicator is just a decoration, it does not function.
Depending what version you get there are different tells... KW A7750 I have:
1) Some of the numbers are a little too thin on the dial - mainly 8, 10, 11
2) Obvious balance wheel is in the wrong location, behind 11 not 6
3) Uses silver screws on the deco plates, not black
That's all that comes to mind. It's actually quite an amazing rep. I didnt appreciate how good it was at first (it was my first rep) but now owning a few more I can see how good that one is.
zxcv81
168
Thank You!
Snaaakeey
252
Uk
Double ar
Thenextpage
105
FYI; I'm about to order this model also. I'm ordering it to replace my first PAM (359) with the seagull movement. That movement has given me several problems and is now dead, so I'mm definitely going with the 7750 this time. I have other 7750's and never had a problem. I've read several reports of people with problematic seagull movements - and from what I've gathered they are generally low quality. But they appear to be more close to gen in appearance.
zxcv81
168
Thank you guys!
Between the Asian movement and Seagull, the differences are only of "internal movement" or even aesthetic?
