New C+ Factory Pepsi
2fast4lust
Sexpert HorLanLogist
688
1,218
Dr. Miller's Planet
Hi all,
Just received some news that there will be a new factory emerging doing the 126710BLRO Pepsi.
New insert seems to have some purplish hue to it and the red seems to be darker. Still Fantasy color? I guess we will need more pictures to find out.
Case from the pictures seem to be prefix 73 which coincides with clean cases.
Crystal is said to be deep, which most of you have come to be accustomed as the crystal that BTF uses.
Bracelet and Claps is said to be using ARF mold.
BIGGEST RUMOUR OF ALL: it will be using dandong's newest 3285 superclone. (Lets wait and see, i do not have any pictures of the movement yet)
Here are the pictures below, as i've seen them. Will be updating here if i see anything else.
Scottymagic
2,024
1,113
Insert still looks like trash - I don't understand why people fawn over Clean, both colours are fantasy (Blue too blue and red is well, orange?). Still maintain that VRF's new bezel colour (they updated from VRF max) is best with an MK3 Blue and a MK1 red. Not perfect but at least you have correct colours albeit different versions.
DougDoug
30
13
Looks great! No white ring around the crystal.
2fast4lust
688
1,218
Dr. Miller's Planet
When did VRF update a new insert and do you have a picture of the the new bezel to share?
I've known that the mk1 red was present in the VRF Max but i've yet to see anything that looks remotely similar to Gen mk3 blue...i wouldn't even call it blue, its like purplue
Reactions: Yogibear
JustFou
177
76
I want to see it too! If it's as good as you say I might try to get of those inserts!
Sent from my Pixel 5 using Tapatalk
37,507
80,072
Serial looks to be 736D, so that would imply the same case source CF uses. Which means it likely has the same terrible bezel assembly components. That would be a real shame, there is just no reason for that. It's not a complex system.
Yogibear
1,409
619
I swear VRF used clean factory insert. The rest of the VRF was just total trash though. They had nice bezel assembly just awful quality after that.
jkrw247
1,206
502
Yes, that would be an enormous shame which would also be a major injustice to the dandong 3285 fitted in it (if rumours are true)
And if the bezel assembly really is still as bad, C+ Pepsi should be called "COVID positive" Pepsi instead
Reactions: Kostiksch
Scottymagic
2,024
1,113
There you go - this was a small two month window between the max and them making the dumb decision to go to Clean bezel
Wacht
656
270
Subscribed as well to follow if we'll get an early Christmas.
aHero
Watch Bro
4,384
6,467
This could be exciting news!!
37,507
80,072
Insert is really nice. (From presumed VRF video above).
Reactions: Ecender
