What replacement parts are required to swap crystal on Sub-C Noob v5
Smoke
14,093
2,220
Bro I'm wrong the gen gasket size I use is 2.3mm sorry for confusion. Check out my first franken buildhttps://forum.replica-watch.info/vb/showthread.php/186246-Rolex-Submariner-116610-Franken-Build-for-Live1-(RG)
botsyboy
3,227
2,347
U.K.
We will agree to disagree on that then bud.
Maybe your case and parts are not machined well then but the retainer has to go flush to the rehaut base to even be correctly sealed and waterproofed.
I've built and modded around 20 of these and owned gen subc' also so I think I have a bit of knowledge here!
Princewilliam
1,970
1,072
I'm wrong u are right lol.I use 2.3mm I just checked
Is that the gasket that came with the xtal or did you order a different one? Mine came in a blister pack with 2 gaskets
botsyboy
3,227
2,347
U.K.
I always use a 2.3 gasket from my supplier and never the bubble pack ones. They are sometimes a little too thick for the rep tolerances.
Smoke
14,093
2,220
I use 2.3mm gen rolex gasket that came with my 116610xtals
