Water resistance
Watch_Addicted
143
Hi, has anyone tried to use a rolex bought from in time under the water? i would know if i can use the watch in the sea or in the pool, because in the description of the technical features of the watch on in time website is written that the watch is waterproof until 50 mt, but i don't know if i can trust. thank you
Sent from the RWI App
Tucker
Lunnyfied by Raddave
17,906
10,116
Do not trust it. Get the gaskets greased and have it tested before you swim with it.
D
d4m.test
Guest
According to Ryan, all his watches is water resistance tested up to 20m. But in the other hand, he doesn't have any warranty on water damage.
You should have a local watchsmith waterproof and water resistance tested.
Tucker
17,906
10,116
thank you, it is a pity that i can't use a submariner under the water [emoji23]
Its not a real Submariner. Get it sealed and checked. You should be fine after that.
