VSF Upcoming Datejust 126334 with VS3235 72hrs Power Reserve
Tobel
5,505
3,743
hello. I am selling my unworn VSF DJ. If interested please PM :)))
Please read the rules about member to member sales (m2m)
This kind of posts could get you banned, which I suspect you'd like to avoid
Raddave
Administrator
24/12/11
67,017
18,813
You will need to sell that in the sales section when and if you become eligible
NightShot
61
25
Good people
Before few days chinese guy told me that he dont have vsf oyster bracelet on stock snd today i recieved video with weird code on endlinks and Z2Y code on clasp which arf on jubilee have that code which is again weird… i couldnt find that combination of codes on any factory lik rof,noob,bp
is it possible this is from vsf new batch because vsf have 7UL code on oyster clasps
Hi, maybe EW factory.
john doe iii
295
90
I realized that, however being that VSF is closed and others discussed the ARF bracelet in this thread as I read ALL 159 pages, I figured I would ask in this thread as there may be a person who could offer a solution. Thank you.
I have a ARF jubilee looking to swap to any oyster if you happen to have one.
taktloss
Hi Taktloss, ofcourse a watchmaker could fix this, since your watch uses the VS3235 movement, genuine movement parts are a solution. I suggest you head out to a watchmaker on this forum.
Thank you very much! I found one and will see these days if he can fix it! :)
john doe iii
295
90
Anybody franken a blue dial and have the VSF dial for sale? Dial part only.
Teddy Perkins
27/1/22
The CF is though? So whats the issue... very minor differences / some better / some worse, but the CF is just as good as the VSF albeit in very slightly different ways...
The issue is that I still have a ton to research and don't know what I'm talking about. I just saw that the VSF was raided and no longer available. Started researching the ARF as a backup plan. Had no clue the CF was similar to VSF. Thanks for the heads-up! Sounds like I have a lot more reading up to do.
ApIcedOutt
121
14
Some say cf is better some Vsf is way better
beside the vr vs vs movement what would u say is different?
Teddy Perkins
27/1/22
So there are rumblings that VSF may be coming back online? Looking to get my hands on a blue dial DJ. Consensus still VSF over CF?
exilen
936
42
Could someone tell me if this is a vsf bezel?
To me it looks a bit like clean v1
Chinaa108
82
So I got my vsf dj41mm and started a franken with the crown tube. I got this part B24-605-0-G1 but unfortunately it’s too thick. Is there a thinner one available and what is its part number. By thickness I mean the part that threads into the case it’s slightly bigger than the hole in the case. Please help! Has anyone got into this problem
