VSF Sub 116610 Stem broken Tube is glued into case not screwed
FischersFritze
159
34
Hi,
recently, the stem of my crown (VSF Sub 116610 LV) was broken. So I thought to change the crown and stem. The first thing I noticed, the crown of the VSF is not gen like, and the stem was glued to the crown itself. No worries, I had an old TC crown and tube. So I ordered some stems for my TC crown. Next thing, I tried to screw the TC crown on the VSF tube. Of course, it doesn't fit, because of the construction of the VSF tube. Therefore, I want to change the VSF tube to the TC tube and try to unscrew the VSF tube. Next thing I held the VSF tube in my hand, but to my surprise the tube wasn't screwed into the case but glued to the case and the case hole has no screw thread but is smooth without a thread to screw a new tube into the case.
Is that normal for a VSF Sub 116610 I thought a tube and crown would be an easy switch to gen parts or replacement parts. But this construction is nowhere near to gen spec and seems really cheap and unrepairable.
Is this the same for other top-tier reps like clean factory?
35,657
71,278
I've never seen a Rolex rep where the stem wasn't threaded and glued into the crown and the tube wasn't threaded and glued into the case. I use GS Hypo cement on the crown and blue Loctite on the tube.
Even my less than $100 DH Gate shitters have had threaded parts like this. I would question the provenance of your watch.
You can retap your case to put threads in it and then use a matched crown.
FischersFritze
159
34
Hi, thank you for your reply. So it is not normal that the tube and crown stem are glued to the case and crown in a VSF. I attached some photos, where you can clearly see that there is no screw thread on the tube to screw it into the case. As well as that, the stem was glued into the crown with a spring between a short stem and the inner side of the crown. I am a little bit confused about this construction and never expected this of a VSF. I bought the watch from a long-term TD of the forum. And now I am really interested if every VSF is built like this or if this is an indeed some kind of "fake" vsf.
Thomas_M
Rolexoholic
232
121
Sorry to see your struggles with this... Unbelievable.
I thought VSF still keeps high quality in their batches...
Another point to believe that Clean is much better than VSF these days...
18,579
Clean is much preferred in China than VSF. There's a reason why.
Reactions: Thomas_M
engbanna1
Gens are replicas of first prototypes
29/5/23
234
151
KSA
Hi,
This is a sub 126610LV not 116610. Can we have a look at the movement?
35,657
71,278
Looks like the tube has snapped off, the threaded portion is still in the case.
^ This
Tap a square or triangular file into the tube remnant and use some pliers or vice grips as a handle to unscrew it. Obviously take the movement out first.
Never seen a stem like that, wtf. The watch does look like a VSF though, R25 serial and all. Guess I better go look at some of my VSF stems, smh.
Zeta7
1,147
1,165
If you want it right send it to a watchmaker. Otherwise remove the movement. Get an ease out screw remover set and give it a go. It should come right out. Get you a good 7mm stainless crown and tube and install them. The factory workers don’t care about anything other than the number of watches they assemble per day.
FischersFritze
159
34
I don't think, that is the case here. I missed posting the picture of the tube. You can see it below. The Part, that went into the case is completely smooth, not threaded and nothing seems to be snapped off the tube. I am now genuinely interested if I bought a complete shitty batch and other VSF Subs are gen spec in this area, or if VSF Subs are only great on looks and completely off when it comes to construction.
No, it is a 116610LV dial might look black in some lightning, but it is green. Also, the case shape and lugs are in line with an 116610. For the movement, please see the image below.
Hor-Fan
When the going gets weird
4,823
5,917
Bat Country
I think that smooth part is from the crown, it’s the barrel that houses the spring.
Reactions: pompompurin
Zeta7
1,147
1,165
Could be someone slapped a vs3135 in a pos case and sold you a Frankenstein as a VSF that was made from a shitter with a vs3135 movement.
engbanna1
29/5/23
234
151
KSA
VS3135 from VSF should have a serial number engraved, is it there? Also what is the code on the clasp? 3135 print looks shitty! Rehaut serial number starts with K25 or R25?
Zeta7
1,147
1,165
The serial number looks like it starts with k25. I wonder how many others are like this. He’s gonna need someone with some serious skills to fix that hunk of 💩 or another case.
Raddave
Administrator
67,017
18,615
BP used to do that many moons ago
engbanna1
29/5/23
234
151
KSA
VSF Submariners are from bad to worse. I have received many with problems such as datewheel jumps two days, clasps doesn’t close/click in a good manner, bezel action clogging, etc. Not to mention the weight, a year a go, I used to get 157-159g on all VSF lines, now, I barely get 152g!
roromush
15
Interesting to see this, most guides will say that VSF > everything else. Is the assumption now that Clean is producing a better product on newer Subs?
Reactions: Watch Hunter
