VSF Panerai Submersible Wrong Xstal Issue ( Say Goodbye To Amplify Effect Xstal)
RobSe1
goes Deepsea
2,274
2,646
Now you guys got me hahaha ... after some time of "i dont see it, i don't care" i now also want the Upgrade with AR :ROFLMAO:
Reactions: samsoniteman
bertieng
1,268
484
Any idea how to remove the turning bezel of the Submersible? Just pry it off with a watch knife opener? Tks.
Tomze
666
218
GER 🇩🇪
etashazam
No more watches pls
819
834
There is no need to deal with the watch bezel; it seems to come with the case together. Therefore, it is not necessary to separate the bezel from the case in order to exchange the bezel.
bertieng
1,268
484
In such case how to change the crystal? Shouldn't there be a crystal gasket and retention ring to hold it up in place? How could this be done without removing the bezel?
BTW, is it necessary to change the crystal for the VSF PAM1055? Is the ex-factory crystal having the fisheye effect?
Cheers
etashazam
No more watches pls
819
834
Cheers
I'm sure, bro. I attempted it once on my own, the xtal came out but the bezel remained. I simply reinserted the crystal and it was fine.
It appears that the bezel is separate and working independently .
However, I suggest you consult a watch smith to handle it!
1055 will require an upgrade.
bertieng
1,268
484
Thanks for the info.
So you mean pushing the crystal out from the underside using a crystal press?
etashazam
No more watches pls
819
834
just received the new pam1231 42mm carbotech!
My AD offered me $17k plus tax here in CA, but I found a brand new one in Asia for about $12k including tax, still expensivo I think.
Thank you VSF!
patnaboy
1,501
4,801
@Woundup Perfect! The 968 factory crystals have a significant fish eye effect at extreme angles. This crystal is so much better (y)
Reactions: Woundup
Woundup
YNWA
2,701
11,485
It certainly is, S... Next up is the 382 and then perhaps the 692. Now that I've done a few xtal swaps myself and getting the hang of it the confidence is growing... Now if I could only find a good method to get those bloody movement retaining tabs reinstalled ....
bertieng
1,268
484
Is it a etashazam crystal? Non AR or double AR?
Do you mind to share the steps of how to swap the crystal out?
Cheers
Woundup
YNWA
2,701
11,485
Cheers
Yes - 2xAR
It's a relatively simple process, though only if you have to proper tools (my experience anyway) for each step. On the next one I'll take pictures of each step and post a tutorial.
Reactions: @(^_^)@
bertieng
1,268
484
Yes - 2xAR
Thanks.
Understands the crystal press is the key tool for the process.
Looking forward to seeing your tutorial.
