Starting this thread to keep myself accountable to a franken Tempus Machina 216a project. Given there have been so few of these over the years, I figured I am the latest brave soul to try and make a go of this as I get sucked deeper into the rep game. After an initial thread about finding someone who could do the casework, I've decided to jump all-in!
I've always wanted a Submariner, but something with a little less visual weight; not having crown guards does make a difference. I considered the HS01, Artisans De Geneve one, but the 216a has the closest blueprint I plan to follow
Upon receiving the watch, I was a bit let down by the cloudy crystal, dull bezel numerals, loose bezel mechanism, and thick lugs. I was fine with the supplied crown, but it wasn't close to the 8mm Brevet crown it's supposed to replicate. I believe the one the rep uses is the same 8mm crown on the larger Yacht-Master, only with "Brevet" text.
While I can't figure out how they did it, here's my method so far:
Every time I've added layers of enamel paint, sanding it down makes it dull, and the paint underneath continue to have bubbling. I haven't figured out yet how to create as smooth and clean of a finishing as the real 216a.
Here's my latest efforts (before and after sanding). I may just skip the sanding
Base Watch:
GMF 216a Rep (from @sead1999)Upon receiving the watch, I was a bit let down by the cloudy crystal, dull bezel numerals, loose bezel mechanism, and thick lugs. I was fine with the supplied crown, but it wasn't close to the 8mm Brevet crown it's supposed to replicate. I believe the one the rep uses is the same 8mm crown on the larger Yacht-Master, only with "Brevet" text.
Crystal
Last year, I sent my watch into @rnrprof to be AR-coated. Since the Tempus Machina 216a comes with a custom domed sapphire crystal (as does the rep, but is less domed). Looking much better now that it's coated. It's been with him while I put this project on pause, but it's time to get it back and continue
Crown/Tube
I've ordered a 8mm Brevet Crown and Tube from Athaya (I've read it's the best out there) -- will need to find someone to tap/install itBezel
Gen Insert
Like the HS01 and Artisans De Geneve model, the 216a has a modified red triangle with the pip removed. However, unlike the others, the red triangle is more 3-dimensional (not flat). See the below picture for reference. I decided to purchase a Gen Bezel Insert (and removed the pip) as I felt this would be more reliable than a VSF Bezel that I'd have to send off to get platinum-sputtered.
- Used oven bake clay to create a base in the triangle area and fill the pip hole and add a little elevation
- Add a layer(s) of enamel paint (Porcelaine 150) to try to create glossiness and 3D impression
- Bake in the oven
- Use filing sticks to try and shape the triangle (which makes it dull)
- Notice errors, scrape off, and repeat steps #3-5
Bezel Assembly
I've bought gen click springs (from @Sub007) in the hopes they would improve the bezel mechanism. However, I need to find a more appropriate hytrel ring (don't want to resort to fishing line mod, and tried buying from Oascom, but that did not work out for complicated reasons)--open to suggestions hereWhat's Ahead (Seeking Advice from the Community)
- Modder who can do extensive casework?-- I need a watchsmith (preferably US-based) who can do complex casework--the lugs need to be thinned further than they currently are, and the chamfer enhanced
- I reached out to @Nikz19, as he's done similar work in the past, but he's EU-based and going through a difficult family situation right now
- I've ruled out doing the casework myself due to time/complexity
- Customized Gilt Dial Design-- I'd like to replace the rep dial with a gilt dial eevntually, as the rep dial has gold markers VS gilt detailing
- I can handle creating the dial design myself
- However, I need someone who could print a true gilt dial -- Besides @manodeoro, who helped me with another project, is there anyone else recommended?
- Hytrel Ring/Bezel Assembly -- What else can I do to ensure a strong bezel mechanism, and what are good sources for hytrel rings?
- Movement Swap--I believe this comes with a VR3130, but I am hoping to swap for a VS3130
- Franken Parts mismatch requiring a VSF 114060 watch and more extensive case modifications
- There's a chance that these gen parts won't work with the GMF watch, which would require a more complex workaround: Purchase a VSF 114060 and find someone who can shave the crownguards and create a modified coin edge bezel
