Submariner 116610LV,comprehensive comparison of GEN, VS, Clean, ZF and KING!
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Our previous WhatsApp account is temporarily unavailable.
We have switched to a new contact:
WhatsApp: + 86 135 0241 3035
Please add us using this number.
Hello, guys. I'm Steve and I'm back. We've already done two comparisons of the Submariner series, 126610LV and 116613LB, so let's get back to the classics. As the ace of the Submariner range, the 116610LV needs no introduction to its popularity, so let's get started.
Dial front view
View of the dial in natural light
View of the dial under lighting​
116610LV has a famous name in our country, that is “green water ghost” (hulk), so the dial color has naturally become the focus, the gen color is dark green, after repeated observation and comparison of the real objects, VS and KING's color is the closest to GEN, especially KING's black and green gradient effect is the most similar to GEN, Clean is also good, but the radial pattern is a bit stronger. The biggest color difference is ZF factory, too bright. But it is difficult to notice the difference without comparing them side by side. Which factory do you think has the better color?
Side view of bezel​
The VS factory uses the V4 of the clean bezel. The color and brightness of the clean bezel are very good, and there is almost no color difference compared to the GEN, while the bezel of ZF and KING are also actually very good, and there is no difference between the color and the clean bezel. After checking with the factory, ZF factory claims to be using the clean V1 bezel and KING claims to be using the clean V4 bezel as well.
Side view of the teeth insert​
The shape of the KING's teeth is distinctly different from the GEN's, and the brushed finish on the side of the ZF is too obvious, which has led to a more pronounced depth.
Side view of the glass​
VS and KING do not have chamfered mirror edges, and although clean and ZF do, they do not have the same shape as GEN.
view of the bezel digital​
As explained earlier, all four factories use the Clean bezel, and the clean bezel is worthy of being the best submariner green bezel available today, with a platinum filling that is very close to the GEN color and a very regular and fine filling. This is why all the major factories have adopted the clean fitting, which shows that it has been fully accepted by the market, including the factories.
Pearl View​
There are slight differences between the factories and GEN colors, VS and KING are slightly whitish, while CLEAN is a little darker, ZF is too yellow and the edges are raised too high.
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Sticker side view​
In addition to the ZF factory,other three factories have done chamfering, especially the ZF dot scale is obviously different with the GEN , you can see the side has a prominent section.
Luminous Filled View​
The luminescent filling of the hands and indexes, which have a certain granularity, are not so different from each other in this respect, it is hard to say which one is better or not, as long as they are not smoothly finished.
Oil font View​
The control of the oil font in all four factories is very good, but if you zoom in on the picture, the ZF is not good enough in some places.
Hands View​
Clean center sleeve is very well made, very close to the GEN in cross-sectional shape and height, the VS and KING are different in shape but still very well made, the ZF has obvious burn marks.
rehaut side view​
The engraving of the rehaut varies from factory to factory, In comparison, Clean looks clearer overall.
Calendar window side view​
The edges of the window are chamfered by VS, clean and ZF, but not as much as by GEN, and not by KIGN.
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Crown side view​
There are no obvious differences in the position of the crown, but a friend recently asked me about the crown logo not facing upwards when the crown is tightened, so here's an explanation:
For comparison purposes, all the watches were photographed with the crown unscrewed, and the crown orientation was random when tightened, as is the case with the genuine one.
Case side view​
Backcase view​
In comparison, the edges of the teeth on the ZF base are not very well finished and are not very flat in places. The genuine product seems a bit dirty due to its age.
Endlink side view​
The position of the endlink is slightly different between the factories, but I think VS is closer to it than GEN.
Strap details view​
The engraving on the inside of the clasp varies from factory to factory, so you can compare for yourself. There is definitely a clear difference between the macro photos and the GEN, but to the naked eye it is not really possible to tell who is better.
Laser Marker and Luminous View​
The factories laser markers are all similar in shape and the luminous colours are all the same as the GEN.
Movement view​
All three factories use the VS3135 movement, except for ZF, which uses the VR3135 movement. Clean and KING movements do not have movement code numbers engraved on the mainplate, while VS and ZF do have the movement code engraved, but the VS is yellow.
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Data comparison chart​
Note: All watches are measured in a clamped state, and there may be errors due to the slight deviation of the position of the caliper. In addition, GEN intercepts the strap, and the factory has a steel strap protective film that has not been torn off.
Well, today's post is here, thank you guys for watching. If there are any mistakes, please correct me. If there is anything else I overlooked, you can put it up, and I will try my best to complete it. Welcome to comment and exchange!
I will continue to bring you more detailed comparisons between replica watches and GEN’s. And it is also for you to choose the favorite models conveniently.
Illustration: Some photos deviate from the real object due to the light source. For details, please refer to the content. The size of the comparison picture is relatively large, you can download it and enlarge it for comparison.
There is no perfect replica, only the one you prefer.
Thanks.
Steve
Website: http://www.theonewatches.ws
Telegram: u/Theonewatches_steve
Wechat: The5711
mrsullivan
Pink Replicaddict
10,065
21,120
Thank you for this "versus gen" review.
Pleasant surprise with the quality of newcommer King, overall the rep Hulks have come so far to be nicely close to gen today, thanks to factories competition on the LV.
Very nice work thank you, this helps and keeps us up to date with the factories's offers 🙏 (and now I need a VSF Hulk, damn you @steve_theonewatches :ROFLMAO:(y))
nunada
70
51
Great comparison post! Thanks for this. The 116610lv really has come a long way in the rep game. I still remember the dial and bezel being so off just some years go
Repmaster1337
DO NOT TRADE WITH ME
2,647
1,807
Sick and well done Steve. VSF have the best hulk now imo
Reactions: Gmc
BUBEST
MULTI ACCOUNT
4/11/21
33
nice work steve!
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Indeed, the competition between the factories has brought the replicas closer together, which is what the enthusiasts would like to see.
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
812
2,657
Indeed, when making comparisons, the quality of the newcomer KING does also surprise me , and the addition of more factories will all bring the representative closer to GEN.
Snookit
79
Great comparison, nice job!
That king dial surprised me a lot.
What happened to ZF dial? Is this a new version, old dial was known as the best one but this version is quite poor in colour.
Old comparison from puretime:
shotgun
3,233
1,526
King have best dial color in this pics..I Think uses BP dial for this watch
Reactions: Sdc83 and Snookit
