Short update, hopefully with photos tomorrow.
I had to redo the 67 because of several tolerance issues that were just unacceptable to me. I could make a running watch but it just didn't fit elegantly and a few issues built up to the point that I redid about 70% of the printed designs (nip and tuck 0.1mm here and there, mostly) and the entire dial stack. The good news is that the redone configuration is much easier to assemble, work on, and live with as a daily watch. Movement is switched to a different variant with a higher cannon pinion so I can get more detail layers into the dial but otherwise is the same.
I'm actually building one on commission right now. I don't want to say that they'll be widely available once finished but I should be able to acquire enough parts to sell a limited run and help defray the cost of etching and my time. Price will most likely be in the microbrand ballpark given that it's quartz, and I still need to figure out a source for some better hands, but for those interested there should be a small run available sometime in 2024, with the exact amount dependent on the parts I can get.
Also continued work on the RM07 - that one fits together great but nailing the exact tolerances for the movement retaining tabs is taking some work. Looks like printable crystals are usable but I still like sapphire better.
I've also finished a design for a conversion kit from the dizzy hands rep into an RM33-02, and a version that can hold a skeletonized NH35. Once I test fit that I'll get the midcase printed in titanium. Big hurdle for that is the custom strap required and the custom strap insert I need to engineer.
Pics soon! I'll be taking some photos of the commissioned piece as soon as I can.
