Refrence guide for xtals
mrrobot
40
22
Resurrecting to say thanks smoke! This cleared up some slight confusion on which is correct for sub-c.
Reactions: Sonil
Rbrobson
31
Smoke / All -
I was wondering if anyone can break down what the various components of the ref number mean (ex. B25-295-CAR-V5-C1)
B25: ???
295: ???
CAR: Cyclops / Anti-reflect
V5: ???
C1: ???
I ask because I am building a YM (40mm) 116622. Based on previous research I purchased a B25-295-CAR-V5-C1 crystal. But this thread lists the "V3" version for the 116622. I am trying to figure out if i need to buy a new crystal, or if the V3 vs V5 is just a gasket or something.
Appreciate any help!
Reactions: rickirocket
john doe iii
295
90
Smoke / All -
B25: ???
295: ???
V5: ???
C1: ???
Gasket size.
srhoque
3,259
2,467
or Rolex b25-318-c-v4-v1 ?
The ARF DJ41 126334 took B25-318-c2-c1. Probably VSF will be the same.
No sure but b25-318-c-v4-v1 is probably the same but with different gasket sizes in the package.
Tijdwijzer
962
606
Europe
Is a gen gasket necessary when installing a gen crystal in the ARFv3 datejust? Or will the ARF gasket be OK?
McPwn
291
116
Looking for Gen Xtal for DJ41 and found some for b25-318-c-v4-v1, think it should work?
paulvillo
696
51
No date gen xtal vs rep dial with Cyclops removed is not much diffent. So I would not bother with a gen no date xtal
Interesting! Got dragged back in after the latest necrobump by [mention]McPwn [/mention] only to read this.
Been on the fence about replacing my Noob/BK/PBDad 114060 for ages... thanks once again [mention]smoke [/mention] ;)
Gaz1a
Franken Monster
664
441
LAX
Hi,
I’ve read the xtal guide by OP - which is an incredible guide thank you. But I’m slightly confused, I got offered this… but the numbers don’t match the sequence on this thread for 16610… is this still accurate for 16610 - as in no AR on cyclops. I just wanted to check as this is “b25-295-c4-c1” and not “b25-295-c2-c4”
Gaz1a
Franken Monster
664
441
LAX
If anyone has B25-295-c2-c4 in their drawers, please reach out. Thanks
Rubiss
208
15
Hello
what is the reference of genuine rolex sapphire crystal?
i am looking for one to install it on gmt clean factory
