Received order and watch makes weird Noise
Skyblob91
49
17
Hi everyone,
Just received AP 15500 blue dial from ZF.
Waited 3 months to receive it and here what i got.
Please listen to the noise it makes and let me know if its normal please?
Thanks
Maximillian
3,250
6,358
Böhmerwald
Hi everyone,
Thanks
Are you referring to the rotor noise? It's normal I think. You can find a watchmaker to silence it if you wish.
Jossé
2,690
7,408
The fjords
Seems like a loose rotor, abnormally noisy in my opinion.
You can try tightening it if you have the tools or as mentioned above take it to a watchmaker.
Skyblob91
49
17
Yes the rotor noise exactly. I have other AP’s and they don’t make as much noise as this one. It’s like if this one has friction.
puretime
Trusted Dealer
Trusted Dealer
16/3/06
14,906
5,528
This watch has some sounds but this doesn't sound correctly. Probably the rotor is loose or fallen. Please check with a watchsmith first if possible, It should be an easy fix. If can't fixed, please email us for further assistance, Thank you
Reactions: Rx4Time
Skyblob91
49
17
Will do and keep this thread updated. Thanks
OnTheSly
51
47
Best Coast
I just got a Glashutte SeaQ that had that exact sound. I opened it up and the rotor screw was loose in the case and the rotor was rubbing the inside of the caseback. I was planning on replacing the rotor anyway (the rep rotor doesn't have enough mass to fully wind) so was an easy fix.
Reactions: Skyblob91
domiffm
handsome
6,226
18,637
Sounds normal to me. This is a ball bearing based rotor. They make (more) noise than jewel based rotors.
Just grease the rotor ball bearing and the noise will be less. However, this rotor will never be fully quiet due to the mechanical construction.
Skyblob91
49
17
Thats what i plan doing is checking a youtube video on how to do this myself
Skyblob91
49
17
Thanks alot !!
Skyblob91
49
17
I’ve decided to ask puretime to send me a return shipping label for them to fix it for me.
I will keep this post updated.
Skyblob91
49
17
So Ive brought the watch to a watchsmith and he told me the rotor is defective because theres friction and to either ask puretime to send me a new movement for the watch and he will install it or return the watch so they put a new movement in it
OnTheSly
51
47
Best Coast
Did he say there was friction at the rotor bearings or there was friction between the rotor and case back (ie, the rotor is scraping the case back)?
puretime
Trusted Dealer
Trusted Dealer
16/3/06
14,906
5,528
I am afraid to say we can't send the movement. If the rotor is defective, we try to order the rotor for you? He can fix it with a new rotor? Otherwise, please return the watch to us, Thank you
Skyblob91
49
17
The rotor is scraping the case back so its friction between the rotor and case back.
