Hi all, I’m looking for some advice, so I’m okay if you want to point me in the right direction. I’m sorry if this is a duplicate, I couldn’t find the answer from searching.
I have partially assembled a 2824 raffles Tudor Prince Date. I think I have the dial spacer, dial, and hands attached properly. Everything seems to work fine outside the case.
I can also screw in the now-assembled movement to the movement spacer that was provided in the raffles case. The problem is that this is loose from the case as a hole. It does not stay affixed, and can move around and leave a gap between the dial and the chapter ring (?), even when the case back is screwed down.
I’ll attach some photos here that hopefully demonstrate how everything is attached on the backend of the movement. Any guidance would be greatly appreciated.
Many thanks.
Many thanks.
