• It's our birthday and YOU get the gifts! Eight giveaways including six watches that you can enter for free! RWI Birthday Free Gifts Link
{*PCTeam*} KW PAM 622 - very small review
ALE7575
Section Mod
19,847
433
Ale, would you recommend 622 over 587 for a 1940 radiomir rep?
Sent from my SM-G900V using Tapatalk
Having Closed caseback with Manifattura movements, non engraved inscriptions on dial, and more simple sapphire crystal, PAM 622 will always be better
ALE
rocketdogbert
1,774
40
Uk
Anyone know if the movement is top loaded on this.
I can go check, any reason you need to know?
not very clear, iPhone only pic, sorry, but underneath the decoration plates are definitely two normal movement holding screws, so I'm going to say rear loader, but a ball ache to get the movement out
svshawn
527
160
Crystal looks to be a little clouded and I wanted to clean it. I took the case back off but not seeing any movement tabs unless they are hidden under the decoration plates. Don't want to mess with removing it unless that's where it is.
svshawn
527
160
Thank you buddy. Much appreciated!
rocketdogbert
1,774
40
Uk
If it's moisture, crack the case back very slightly and put the watch in a bag of dry rice for a week or so
cal8500
193
Deco-Plates (look post#1):
- movement: bare bone Asian 6497 with decorative plates to mimic I don’t know what ;) I tossed them right away - since they were mounted with double sided adhesive tape, not so strong.
My experience is, that the movement-tab screws mostly are not tighten very well, so movement is not fixed as good as possible. I always have to tighten these tabs at my watches.
So I suggest, to remove the deco-plates and tighten the screws. (After that fix the plates with new and better tape - if you need it for your mind - otherwise toss it away and close caseback.
If you want to remove movement, you can do this on the back - it's a "rear-loader".
For (real) cleaning the inside of the crystal, I strongly suggest, to use BERGEON Rodico, otherwise you will get narrow with dust under the crystal.
svshawn
527
160
No water damage just anal as can be lol. I have a waterproof tester on the way and excited to have all my watches waterproofed.
cal8500
193
Really big flaw I noticed yet, is the fact, that hour hand has same broadness as minute hand.
Gen has more broad hour hand than minute hand:
ALE7575
Section Mod
19,847
433
Thanks. This could be a nice catch
But the rep has bigger minute hand width than hour hand
Maybe the gen difference is greater
ALE
JMMC
330
rep hour hand is also thicker, seems pretty right to me. May be angle different angles of view made the difference.
cal8500
193
I have checked - your both are right - but the difference is not noticeable by eye. Because it's too minimally.
ALE is right:
ALE7575
Section Mod
19,847
433
Yes, greater difference on gen is almost evident, but in real size that will be almost unnoticeable
ALE
