This how this insert looks like flatted and with a gen pearl installed
Enlarging a hole to retrofit a new pearl is easy. Just figure out the diameter you need and buy a drill bit. You can run the bit thru by hand, no drill required. The aluminum on these inserts is soft. It carves like jello!
I did it on 4 or 5 inserts already.
