qsb5, the bezel insert has a hole but it is smaller than the pearl. Did someone changed the pearl to gen one I remember? So it should be possible to drill a bigger hole for the pearl. Insert is really thin so be careful.
Installation was easy, I took a sharp knife and made a small hole to insert and bended it off. As I was too keen to take it off quickly, I made a small scratch on the bezel
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It would not have happened if I would have made the hole more center to the insert. But nevertheless taking off is easy, there are many threads telling how to heat up the glue or make a hole. If you can take off the whole bezel changing insert is easier. My method destroys the old insert (I would have burned it anyway, it looked awful so no harm done).
New insert is not exactly the same as old so I took a bit aluminium off from the backside of the insert (same way as someone did when he changed gen insert to rep bezel).The insert sits a bit higher on the bezel than older one but I don't mind because you cannot see it really. The diameter is the same so it is a direct fit.
Although my pearl is not centered it is a huge improvement to older green one. And luckily new one is on its way!
