Mini-Review of the Eurotimez "upgraded" V5 Deepsea Sea Dweller
jmb
1,449
I have no idea, BUT if you want to front me the scratch to get one of each I'll gladly rip 'em apart and see! ;-D
pedecter
447
I'll front you for the Rollies, if you'll first front me for a Concord Tourbillion I've been eyeing. Deal?
jmb
1,449
Hmmm, generous offer but I don't think I'm THAT curious! ;-) That is a strange looking beast, will it not have a crystal in the classic sense?
jmb
1,449
That's a fascinating watch but I have to wonder about it's durability! ;-)
pedecter
447
It's only meant to be worn on your yacht while it's in dry-dock, and you're in the clean-room in the cabin.
jmb
1,449
Oh, I didn't think about that possibility! I think, though, it is a wicked-cool looking timepiece!
jmb
1,449
Several folks wanted "lume shots":
First is pretty much "life-sized":
Second is slightly magnified:
avenger007
5,704
692
That looks pretty darn good, Justin. This one is steadily climbing my "next buy" list. It looks like they got a lot of things right with this one. Can't believe the deal you got.
jmb
1,449
Same deal you can get! If you e-mail 'em you can get your choice of 4 different movements. The only flaw I have been able to find is the bezel insert is off maybe a half a click and on the geek somebody pointed out that all V5s he's seen seem to have slightly "slanted/crooked" dial text. I could see the dial issue on a macro photo after it was pointed out but I really can't see it in real-life on the wrist.
techlogik
477
You mean when the bezel is clicked it doesn't align with the markings? You can fix that probably, open the back and undo the 2 screws for the movement holder slightly. This will loosen it, then turn the movement holder that holds the dial some and see if it aligns properly. Re-screw. I had to hold the movement with slight pressure and tighten the screws on mine. Hopefully it will do it enough to align it with the bezel, yet not throw it off from the general alignment and the crown stem is still pretty straight and not putting any weird presure on it. That's what I had to do and it worked on mine.
Yeah, the slanted dial print issue once I noticed it, I can't stop looking at it. This is a shot of my Eurotimez V5 out of the case as mentioned in the RG thread. It is pretty bad. I am waiting for Eurotimez to get back with me on this issue.
jmb
1,449
Dr, No way to tell from that angle and size...
Tech, never entered my mind to rotate the movement slightly. Thanks for the wake-up slap! ;) As soon as I can get the back off (so far my sticky-ball won't budge it so later I'll try a wad of duct tape) I'll do that as it bugs me a whole lot more than the amount of "dial tilt" in my example.
Dr.Verylong
10,405
12
jmb, thank you for looking. I credit the distortion to the wide-angle lens.
Well I gave the ok, the watch is on its way to me and I'll hopefully find out pretty soon ... wouldn't be nice to get an ETA DSSD with a tilted dial ...
Can't get to sleep in fear of getting a slanted inscription
Dr.Verylong
auwareagle01
33
I've seen this dealer mentioned several times around the forum....Are they one of the "TRUSTED DEALERS" just a different name??
techlogik
477
Dr.Verylong
Did you ask them for photos of the watch before it is sent? Ensure a straight on shot of the dial clearly, you will be able to see it. Let us know though when you get it and post some photos...I want to see if the streak continues.
