How to spot Standard / Elaborated / Top / Chronometre Versions of 7750?
gwallabie
287
67
The search is on...
According to this:
"the ETA 7750 is only sold in Elabore, Top and Chronometer grades"
This mnakes the search a bit easier, Top and Chronometer grades are the same for me (I do not need the extra certification) so I only have to sort out the Elaboré grade ones.
It would also be helpful to know what type of ETA7750 movement will be used in TAG-Heuer watches.
Most 7750's on ebay are with a TAG-Heuer rotor...
KushBandit
1,508
2,287
Whisky-A-Go-Go
Standard and Elabore grades use a Novodiac/Etachoc shock absorber. Top and Chronometer use Incabloc. This is the easiest way to tell.
Pallet jewels on a Standard and Elabore grade are Polyruby, Top and Chronometer are Red Ruby.
Balance wheel and hairspring are also different between Standard/Elabore and Top/Chronometer.
gwallabie
287
67
Thank you - how do I identify Polyrubi vs. Red Ruby? Colour differences on pictures are sometimes not easy to tell.
Can I see the differences between balance wheels on a picture?
I checked now the 7750-pictures in a lot of ebay-deals - i have only seen Incabloc schock absorbers, also by the ones advertised as "elaboré" from Switzerland.
Energo
747
70
7750 Top and Chronometer have Balance wheel is made of the glycidur alloy. This wheel has not straight, but curly needles, as in Asian 7750
gwallabie
287
67
Thanks,
found only this picture - left side: normal, right side: Glucydur balance wheel?
Unfortunately it is not always easy to see the difference, if the movement was still running as the picturec was taken - you do not see it.
Energo
747
70
Top and Chronometer is always decorated with a perlage or Geneva waves.
gwallabie
287
67
Thanks again, found some on ebay stated as top - but without any decorations. It seems that there are no strict rules at all.
There are a lot of TAG-Heuer Calibre 16 movements offered - also some with genova waves - but I read somewhere that TAG-Heuer uses only elaboré and no top or chronometer movements from ETA. They adjust the movements themselfs. (?)
This is nóone offer which seems to be a "top" movement with glucydur balance wheel:
