Help Installing handset ETA 2892-A2
Hec
| SELL ME YOUR 6542 SERPICO |
880
3,222
Spain
Hello,
I'm having a breakdown installing my new movement on an IWC Mark XVIII dial.
I have bought a Gen 2892-A2 movement, fitted the dial to the movement, tried all the crown positions, so far so good.
The problem I have had is using the retaining ring from the clone movement, in the end I have managed to put it on but could it be that this will give me problems installing the hands? Or maybe I have installed the ring in the wrong position?
When I try to put the Hour hand there is no way to fix it, I have seen tutorials, and it is not so difficult.
The clone vs gen movements seem to be the same size but I'm starting to have doubts, I'm attaching a photo in case someone can help me or explain if I've put the retaining ring wrong,
I think it doesn't fit because it doesn't protrude enough.
Thanks to all of you
36,488
75,105
Hello,
Bro I'm not familiar with that movement holder, my only IWC has a DG2813 with a different holder.
But, your datewheel can't physically get any closer to the dial so it looks like your issue is the gen movement hand pinions are too short. ETAs have many different possible pinion heights and many gen movements come with the shortest ones.
It's often possible to use the rep hand wheels but if you don't want to do that you need to measure the rep pinions and buy a replacement kit.
2892 hand pinion kits
The hour wheel and canon (minute) pinion can be easily installed on the dial side. The seconds pinion requires removal of the train bridge on the movement backside. LMK if you need help with that, I can post a video.
mclarendude
30,355
37,307
ATL
I remember having to use the hand wheels of a rep 2892 on a gen 2892. As KJ said, it is an easy swap. From the look of yours, it even looks like it is missing a wheel, but I could be wrong.
Hec
880
3,222
Spain
Thank you for your answers.
@mclarendude @KJ2020
I think my only option is to go through a watchmaker, in the end I thought that putting some hands could not be so difficult ... and then I have already coldly realized that a gen movement is not the same as the clone...
@KJ2020 What "kit" would I need? I see a lot of H1, h2... and I don't know which one I need.
Thank you very much to both of you
Reactions: kidcreole
Hec
880
3,222
Spain
@KJ2020
I thought, my old 2892 clone movement is broken, could I use the parts in the gEn? Although I'll take it to a watchmaker, I'm very novice and I don't see myself able to do the modification right now on my own.
36,488
75,105
You would need to measure your rep hand wheel pinions and choose the right size from the table in the Item Description. It's probably an H3 or H4.
This is not above your capability. You can practice on your rep movement. Train bridge removal is the same as a 2824.
Reactions: Plaasbaas and Hec
36,488
75,105
@KJ2020
Take the rep parts out and examine them for any defects. If none, you can try it. Often it will work but no guarantees. If taking it to a watchmaker, I would give him gen parts so there is no risk of incompatibilities and less risk of accidental breakage.
Reactions: Hec and mclarendude
kidcreole
555
391
This is the path of the hobbyist. One step fwd and two back. It builds patience and character. The pinion swap isn’t too hard but the first time will test your intestinal fortitude. Just do it!
Hec
880
3,222
Spain
Hello,
I have found an original dial at a "reasonable" price, although I still need to get confirmation of use marks etc.
I know that IWC assembles its own calibre, but my question is: with the original dial do you think I could use the GEN 2892-A2 movement I bought?
@KJ2020 @mclarendude
mclarendude
30,355
37,307
ATL
Hello,
As far as I know, it should fit fine. I had an old Omega Seamaster Aqua Terra with an A2892 and I bought a gen dial (for Omega's 1120 caliber, same as 2892) and a new GEN 2892 and it fit fine.
Reactions: Hec
Hec
880
3,222
Spain
Thanks, if I finally get the gen dial I'll let you know.
36,488
75,105
I would ask the seller for two things:
Measurement of the outside diameter
Pic of the backside to see feet positions
Then compare these to your rep dial so you know for sure what you are buying
Hec
880
3,222
Spain
Good point.
The gen dial has the feet in the same positions as the rep.
My measurement of the dial (it is 0.1 mm smaller than the gen, assuming the gen measurement is correct).
I don't have to worry about the handset issue? I will still have the rep, they should fit the 2892 movement?
36,488
75,105
I can't say firsthand but that's a hand-movement issue having nothing to do with the dial. You can check that now by temp mounting the hands with no dial installed. Just be careful not to mar up your datewheel with the hands.
Hec
880
3,222
Spain
Sorry, let me get this straight.
1. I understand that the problem with the hands not going into the new movement is because of the pinion? I'm having trouble understanding this, I'm a novice. The dial and hands were perfect in the old movement (Clone).
2. You suggest that you try to mount the hands in the new movement (without the dial).
3. I understood that the problem is the space between the dial and the movement (in fact @mclarendude pointed out that the date was too close to the dial).
Sorry for the confusion but I made a bit of a mess.
P.D. Anyway I don't know what to do with the gen dial, at least in some pictures I see signs of use, I'm waiting for new pictures from the seller.
kidcreole
555
391
The problem you’re having with the hands has nothing to do with the dial (as long as the rep dial is not overly thick). As others have said the rep pinions are likely taller than the gen has. Therefore the gen pinions do not protrude through the dial sufficiently for the hand sleeves to mate properly. You can quickly understand this if you place the dial over the rep movement and observe the protrusion with a little magnification. Do the same with the gen. You’ll likely confirm Gen pinions are shorter. Also review the diagram to see the relationship in the top left. The pinions are the tubes that poke out of the dial that the hands slide over.
Reactions: Hec
mrsullivan
Pink Replicaddict
9,092
18,960
Talking about 2892, what position should it be to remove the stem ? Time set (3rd) ?
Hec
880
3,222
Spain
I found my own answer 👌
I'm a mere novice, but it's always advised (at least in all the videos I've seen and in tutorials) to remove the stem in the time setting position, the reason is to avoid a keyless (I did one myself on a 2824) although it was great because I learned how to fix it.
Always with the help of the teacher @Karbon74
mrsullivan
Pink Replicaddict
9,092
18,960
Well I always remove my 2824 ou 36 in time set position but had heard before that some other ETA references are preferably positioned in neutral/winding.
I've seen a couple of videos of stem removal of 2892 with the balance wheel running so I wanted to make sure.
I also realize the picture I just uploaded is for 2894 😅
