- 28/5/07
- 1,092
- 935
- 113
As with many of the OCD types on this board, I find that keeping my AP watches in as near mint condition as possible is a challenging task.
Swirls gradually creep into polished edges, and even with the most care to avoid doorknobs, seatbelt latches, and door frames, an occasional little ding can appear.
Avoiding contact with abrasive surfaces and impacts is the best policy, and wearing partly concealed under a shirtsleeve is very helpful in this regard.
However, when things do happen, I've found that careful refinishing can be helpful.
We've all seen the results of careless refinishing, occasionally on reps and frankens, but more commonly on older / vintage AP ROOs or ROs on sale on eBay or C24 that have been refinished by other than AP, or have been refinished too many times.
One must be especially careful with refinishing AP models to use the utmost in restraint, and to protect sharp edges to preserve the geometry and character of the case-- AP itself will limit itself to two refinishes for this reason.
Every polished and brushed face has a sharp edge or crease that should not be softened, and every brushed surface reflects a precise degree of coarseness/grit that must be calibrated to contrast with adjoining surfaces. Moreover, special brushing tools and techniques must be used to retain the "holographic" effect on curved brushed surfaces that result from the random pattern of ultrafine gouges that scatter light at many distinct angles as you rotate the brushed surface.
I've been compiling and testing grits/particle sizes for micromesh and diamond abrasive tools for accomplishing the above, and simple tricks for preserving geometry and transitions.
Would this be helpful, and would other modders be willing to share tips of the trade?
