Ex-ki Corner - Watchmaking tools, reports & tutorials
ciaoman21
140
Yeah ! Congratulation and a very good job to see absolutely, (there are so many oil..).
Reactions: Ex-ki
Ex-ki
1,232
270
France
I finished the building of a custom made watchmaker workbench:
Supplies list:
- a 18mm MDF board
- 8 squares
- a thirtysomething nuts and screws
Purchased from a local hardware store for a few euros.
and 2 adjustable swivel armrests that I had found on AliExpress by total chance: https://fr.aliexpress.com/item/32365279262.html
I was a little apprehensive about the quality but they totally do the job, it's perfect.
Super comfortable, for working in the best conditions and it can be stored in 2 minutes in a cupboard.
DrHack
356
252
SoCal
Your workbench is perfect! I really like the arm rests, that's a great idea!
Reactions: Ex-ki
Ex-ki
1,232
270
France
Thank you!
I thought about installing armrests because I got tired from having them raised when working on movements.
Muskandar
465
125
I really like that desktop style work bench. It even brings the working surface up closer to your face. That way you don’t have to bend over as much.
I really enjoyed this post. Following ^-^
Sent from my iPhone using RWI
Reactions: Ex-ki
KalKala
97
31
Supplies list:
- a 18mm MDF board
- 8 squares
This is GENIUS!
BTW you may consider to put some pads on the arm rests: I have the Horotec Portable Mini Bench that has those flat & fat arm rests that are really useful and comfortable. Can you also rotate them longitudinally to have your wrists above your elbows? (this last question is a bit convoluted, I hope you'll understand anyway!)
I also follow Mark Lovick superb videos on YT: I've also seriously thought to enroll into his teaching programs...
Well done, keep them coming: these kind of reportages are always very useful as reference!
My next step would be to find a proper mainspring winder without spending a fortune, but I cannot find any exact measures for the mainspring barrel diameters you have in our usual Asian movements (2813, 3804, 2824...) and for this I'm not sure what movements' reference I should look for in those kits... Any idea?
Kudos!
KalKala
97
31
Maybe you should replace the arm rests with this type I assume it will be more comfortable and better suited to move your arms more freely without loosing the support.
