Daytona ARF, Noob V1 and Noob v2 2018 Dial and Bezel Analysis
markfisher
457
174
Index also are better now! SEL seem very good from pics. If only Noob could go back to the 2011/2012 dial font, both for ROLEX and DAYTONA writiing...
markfisher
457
174
Anyway there is something strange with rehault height, maybe it’s only the camera angle
markfisher
457
174
Would you please post here how you automatically referenced my pics? Or, I will just have to search and find the way. A pity ^c ^v doesnt work any more.
You simply need to click on "share" tab on picr.me and copy the URL of the image into the URL field of the forum interface to add images (click on the image icon)
Reactions: r0b9502
r0b9502
913
305
Thanks. I was advised yesterday to post the BBcode, which works. But I will try this method too now.
Nothing works now. I am sure tripdog has blocked something!
Closeup with leather strap. I am happy with this combination, although I had purchased the strap in advance to order a panda. These sels from the leather strap have not even a fraction of mm play. Ideally, for this model, the center portion of sels has to be polished. And the sels are designed so the strap does not lie flat in a case when folded. But then, I realize :eek:fftopic:, complaining about the strap and not the watch.
https://www.picr.me/image/URvfD
My wife thinks this is a ladies watch even though she says she wont wear it :(
tripdog
Super Moderator
24,881
23,225
Why are you determined to make everything difficult ?
I scrolled down on your image, clicked on 'Embed codes', I went to 'Full Image' (second block down), put the cursor over BBCode then clicked on 'Copy'. It really is very very simple - I'm sure a small child could do it.
Reactions: hibee999
r0b9502
913
305
Thanks buddy. What I had forgotten from 1st attempt is I had to just put the bbcode link here. I was trying to click on the "attach image" icon on the top and filling the bbcode there. This works now.
Even old dogs will remember a new trick eventually. :woo:
ggrep
11/10/18
Wonderful Review!
Just purchased a 904L noob 116500LN & was wondering if anyone knew which modders are able to do a shave down dial swap and bezel swap from ARF version.
Thank you!
guru
11,750
1,557
Wonderful Review!
Thank you!
read the forum Rolex section
Sent from my iPad with Tapatalk
Reactions: MrBeasy
tripdog
Super Moderator
24,881
23,225
All of it ? That's a lot - but it'll do him good to read - good for the brain.
Reactions: MrBeasy
vcappp
1,000
296
it seems like Noob just uses the white dial again for 904L too without correct the flaw.
ssouthall6
3,539
1,563
Update:
116519
Dial lettering
Most important part of the dial, the bit you look at first 99% of the time
Noob - ROLEX lettering completely wrong, specifically the RO.
LEX is actually ok, so not much for noob to do to elevate this to a 7 really - 3/10
ARF - spacing under oyster perpetual too thick, lettering far more accurate but R still not right - 7/10
Subdials - practically the same, noob groove is a little too pronounced, ARF is not really visible and on the whole subdial not just the outer
Noob - 7/10
ARF - 5.5/10
Reactions: racingeagle
ssouthall6
3,539
1,563
Can you plz compare ARF V1 and V2 dial?
ARF V1 and V2 dial are more or less identical on 116500. Only difference is the numerals on the Subdials are closer to the inner edge on v1.
I could not find any difference in v1 vs v2 on 116520.
Reactions: KJ2020
