I have heard back from my genuine parts supplier that he cannot source a new case set other than from TAG themselves, and at the quoted $1000, I thin I will work on the spare case set I have, and see how I get on with it.
Had some free time today, and with a empty house, I set about disassembling the spare Carrera case. First, I wanted to remove the pushers from the rep case, these are held in place with tiny cir clips locking them into place. The construction, and functionality of these compared to the genuine pushers I have is slightly different, but more on that later.
Pushers removed first so I could get a press die in there to remove crystal later...
A look inside the area of the crown and pushers...
Now lets take a look at these pushers in more detail...
Rep pushers... (notice the small indented ring, this is where the tiny cir clip locks the pusher into place. Also noticed the small black o-ring.
Rep Start/Stop Pusher...
Rep Reset Pusher...
Now onto the comparison photos. The Genuine Pushers are on the bottom...
Genuine with the screw thread...
Genuine, Left...
Next, I popped out the crystal...
Closer look at the crystal gasket, and chapter ring...
Removed the crystal gasket, and took some reference photos on which way its fitted...
Then I set about removing the bezel/insert. This spare case is the chromed bezel insert model, not the black bezel insert like my franken. I am unsure if the construction of my franken bezel is the same as this one, but looking closely at this thing, the bezel insert, and bezel are one piece of machined stainless steel..
Also removed the chapter ring with the bezel as the chapter ring sits under the bezel...
The chapter ring was held in place with 4 x sticky strips. I have also noticed some marking to the case in this area, which looks like its possibly had some correction work done, and marked in the process..
The small hole you see on the edge to the left of the sticky strip is to home the chapter ring centre.
Chapter Ring...
Rear of Chapter Ring, and the dimple which mates with the hole above mentioned...
Some photos of the one piece removed Bezel. Looking closely at this, I cannot see anything that reflects that there is an insert, its all one piece...(looks like theres a lip around the circumference, but this is machined that way...
More marks visible on the rear of the bezel, which has to relate to the factory removing, or doing something with this watch prior to marketing/selling. Seems weird...
Now a look at the case with the bezel removed...
Group shot of dismantled parts...
Crystal, and case back put away for safe keeping. Awaiting for genuine crystal measurements at the moment, which will determine whether or not I will be able to fit a genuine crystal in this rep case set or not...
Trial fit of a gen pusher, just to check tolerances, and there's quite a difference. The thread slides into the case so far, then stops. Unsure at this point if I will be able to use the gen pushers or not due to the completely different construction, and design used with the rep pushers...
Closer look at the hole where the threaded part of the gen pusher stops at. It maybe possible to tap and die this inner area, but then can't see how the gen pusher would work, as its completely different in construction as the rep pusher. The rep pushers have an inner area of the tip of the pushers, which when pushed, the protruding case tubes go into.
So that was that for now, need to do some micro work, and measurements regarding the pushers.
Photo of disassembled case for reference..
And that it for today. Will up date later once I get the tolerance measurements of the genuine crystal from my supplier.
Rep Reset Pusher...
Genuine, Left...
Chapter Ring...
