CF DJ 41 clasp making clicking noise whenever touching surface
Plaasbaas
IWC-hoarder and PAM-hunter
2,685
6,124
OP, are you sure that you tried to bend the inner part as shown in above pic, and not the outer part of the clasp?
The inner part is really very soft...
exilen
924
42
Slightly bend it and if it’s still loose, bend it a little more
I am trying to bend the left part. Does it look like it did bend at all? I tried to bend it by putting my finger like on the Everest page, but I don’t feel like it is bending, and it is also really hard that I am hurting my fingers… Could be I am not so strong as well though…
What I am mostly afraid of is that I will break the clasp by breaking the pins that connects the clasp together
Plaasbaas
2,685
6,124
Well, then it seems that you have the correct approach, but for some reason your clasp withstands your attempts to bend it.
exilen
924
42
I am considering on trying to take a plier to bend the both side of the tip of the clasp so it won’t have space. Do you think that would be a good idea? Or is there any other way to bend it without using my fingers in case I am too weak 😂
exilen
924
42
What do you think of the picture I sent of my clasp above? Does it look bend enough?
I am curious if because I also have a small wrist would be an issue?
kavorca1
cosa nostra for life.
2,447
3,099
SoCal
Try it on. It depends on how loose it was before. I barely bent mine and the clicking stopped
exilen
924
42
Still the same clicking :/
Curious if all CF bracelet has this issue or if it’s because I have skinny wrist
