Ceramic Planet Ocean Part Number Reference Guide
pippo
Put Some Respect On My Name
10/1/10
3,613
189
Is the 42mm dial a straight swap?
Thank you
santre22
1,646
339
Thank you
No both 42 and 45 mm gen dials need a gen 8500 movement to fit directly. And if used with a rep movement you need a custom made DW overlay and modding the dial feet. And those DW overlays don't exist.
pippo
10/1/10
3,613
189
Yep, I thought as much.
Thanks santre22, I was about to order a couple of genuine date wheels
santre22
1,646
339
who sells genuine date wheels for the omega 8500 movement? It won't fit any eta or eta clone as its an in house movement. (Made by eta exclusively for omega) the whole swatch group story I don't want to explain in this thread.
pippo
10/1/10
3,613
189
No, you are right, it was for a 2500 caliber, my mistake. :)
santre22
1,646
339
I can confirm that the gen crown for 42mm CrPO fit the noob tube perfect also.
omegagmt
1,995
Will a gen crystal fit on the 42mm CrPO? Mine is the BP version. It has a bluish tint. Does the gen have the same tint?
santre22
1,646
339
The gen from the old generation planet ocean crystal will fit (2500 movement PO). The gen CrPO crystal is to thick for the rep case.
desihero
5/1/14
47
Does anyone know which dial (noob/bp/gen) can fit a 42 LMPO? Now that LMPO is OOS.
omegagmt
1,995
Will gen hour and minute fit eta 2836? 42mm noob is what I'm searching parts for.
omegagmt
1,995
Did some more research and found that a 2836 and 2824 are basically the same movement. The only difference is the 2836 has a day function and is slightly thicker. Wonder why they would use a 2836 for the PO that doesn't have a day function? Is it so it can fit the case better due to its thickness?
santre22
1,646
339
They used the 2836-2 for one reason, the hour, min and sec pinions are higher to make space for the day disc. In the CrPO is it a DW overlay using this space and the hand stack will be placed correct over the dial. The date change on a 2836-2 is instant and on a 2824-2 it's changing over a 0,5-1 hour period. The gen 8500 changes date like the 2824-2 but the hand stack is more like the 2836-2 as it's a thicker movement. The manual date setting is how ever complete different from any rep movement available.
R2D4
Admin
14,905
42
Black LMPO with gloss dial.. Is a swap part. Meaning, Omega will sell you one if you send in the old "Gen" dial.
letti001
Horology Curious
29/3/13
20
I have ceramic PO that the crown has just stripped. Any luck from anyone in finding the case number? I would like to get the tube and crown from cousins. I found a case number but it is for the ultimate, I believe. Thank you..... Sal
santre22
1,646
339
168.1665 is for the 42mm ceramic model.
