for a long time quieter with reader here in the forum.
some Gen Hulk vs ZZF V2s pics
Could you give your thoughts on the ZZF cyclops in comparison to gen?
i will take more detailed pictures in the next days the sun is not shining well today, then I also give my own rating
Hi guys its been a long time i want to buy a hulk and the zzf v2s colors are beautifull but i prefer the 2824-2 movment for reliability , is it possible to swap the sa3135 by a gen eta or not , if not possible is it better to take the v2s or arf v3 2824 which is more reliable but less well finished
You can swap with 2824 but we know so far that this clone is very reliable and my advice is to use it and if it die for some reason you can swap it with 2824
also if you read the thread you shouldve know that zzf have vr3135 movement and not sa3135
I asked Li and unfortunately this is not true. 2824/2836 will not fit into a case with a 3135
srhoqueSaul Goodman Explained,also if it dies for some reason you can buy new vr3135 movement (isnt expensive)I asked Li and unfortunately this is not true. 2824/2836 will not fit into a case with a 3135
Ok so its a big and difficult modification to do this its better to let the 3135 until its stops working i hope the vr3135 is good, i have already one 2824 and its just perfect
Robi01 how Much for a new vr3135 ?
Ok really cheaper than an eta with assembly , do you think the vr3135 need a cleaning out of the box or as it's a reliable movement this was done correctly at the factory
First I would to thank JJtime Li about the watch. The best version out of the box. Here is my honest review:
Thank you for taking the time to weigh in.
