Rob today my after market crystal gasket arrived. but it's different. They guys who sell this on ebay say Sea Dweller 116660 44mm. But when I try to pressOGEV Ring to the case nothing happens it's not tight at all, does it have to fit tightly? The after one doesn't have the step and the clamping ring do nothing too. You know what part number is the crystal gasket?? 316, 318 or 295??
The right one is the ARF original. Left one after market
It looks like that the notch is missing on the aftermarket ? and it‘s thinner than the ARF one. I think that’s the reason it won’t fit...as for the Crystalnumber i‘m not sure which one is correct.
i don‘t know if ARF is 1:1 like gen or if your aftermark is different. You could also try a TD to get the part from ARF
I will also check some people for the Gasket!
I talked with Prof. Crystal and he say is very hard to find the only way is talk to the TD:huh1: Or used the old gasket and used some silicon sealer around, could be work but just for shower or swimming pool. Anyways he suggest to talk to TD.
Let me see now with Mr.Timezone cross finger ready.....raying:
Something I can do, but I don't sure about it. I will used a Teflon tape in the damaged one all around to create a seal. Teflon tape is very thin but is strong and can take any shape or form. ( i will do this like surgery doctor cutting the plumber Teflon tape with scalpel) This Teflon tape can hold 5000 PSI of pressure in regular thread. This is over a Teflon gasket I don't really know what happened , the good is the Teflon tape can take the shape of the gasket and fill the damaged parts, the tricky here is when I used the pressure ring over the crystal gasket what will happen…….ohh my....let see.
